Old 07-15-2005, 09:36 AM   #1
Deloriant
M50 Intake MF/Shrick Intake MF
Just a question for the E36 crowd...who here has installed an M50 Intake MF or the Shrick intake MF? Did you really notice a larger power difference in the higher RPM? Was it worth it?
Thanks.
Old 07-15-2005, 04:39 PM   #2
Spieluhr
Title: ///M Driven
komodo just did. There are proveable gains. It is a must have.
Old 07-16-2005, 02:36 AM   #3
BaLAnCe17
BaLAnCe17's Avatar
Your Ride: 1998 m3 coupe :-D
either pm komodo or something...he said he lost some torque and thats what really matters IMO...but he did gain more hp up top
Old 07-16-2005, 04:00 AM   #4
Chris
Chris's Avatar
Title: Visiting Mod
i'd pick torque over horsepower..... HP doesn't matter if you get hit by a school buy because you couldn't get going fast enough. HP is over rated. handling and low end torwue are much more important.
someone here on the forums has a quote in their sig that goes something along the lines of "HP just helps you hit the wall faster....one way or another you're still going to hit the wall"
IMO torque is more important unless you just have no horsepower in which case you have more problems than what manifold to use......
Old 07-16-2005, 07:56 AM   #5
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
^^ Finally someone who ses things my way
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 07-16-2005, 09:20 AM   #6
Deloriant
Bah, I guess if I'm gonna do it I'm going to have to do cams at the same time....great concept...but NOOOO CAN'T SPEND MORE MONEY ON THE CAR!!! lol
Old 07-16-2005, 01:00 PM   #7
jrhaile
Rate My Car: 114 / 337
you will lose some low end for sure.. but the top end is great. When I raced 328i just like yours which had an intake, exhaust, etc he kept with me until the middle of 3rd gear and then it was bye bye.. it was like he was standing still...
Old 07-16-2005, 02:10 PM   #8
Addicted?
Title: 350z
Your Ride: 2003 350z Track Edition
yeah if you do end up doing the manifold just balance it out with something for the bottom end! sure more $$ but who needs money anyways
David
Old 07-17-2005, 10:49 AM   #9
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
I did the m50 and I highly recommend doing it! I lost a bit of torque, but it was barely noticeable, but then I installed underdrive pulleys which made up for it. The gains up high are amazing! From about 3.5k to 6k there's a HUGE pull that wasn't there before. It gives your car more power at higher speeds too, like cruising along the freeway at 80, if you punch it you get a nice little kick to move forward, after you're already moving that fast. Sure you loose a little off the line (no joke, it's to the point where you barely notice it, if at all), but the gains up high are very worth it imo.
Old 07-17-2005, 06:08 PM   #10
Spieluhr
Title: ///M Driven
very true. The pullies would do a nice job of countering this loss of torque.
Old 07-17-2005, 08:19 PM   #11
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
m3 cams or a 3.23 lsd would more than make up for the loss in torque. if you are going to get the manifold you should get cams at the same time
Old 07-18-2005, 01:35 AM   #12
BaLAnCe17
BaLAnCe17's Avatar
whats the stock differential in a 98 or any 328is
Old 07-18-2005, 10:51 AM   #13
EuroStyle
Your Ride: 92 325i
If it is a manual I believe it's a 2.91 or 2.93 (not sure about the last number but it doesn't matter).
If it is an automatic it's a 3.91.
A 96 to 99 m3 has a 3.23 which is a great swap option for a manual 328i or 328is.
I saw that in another forum you mentioned that you purchased a set of Bav Auto headers. IMO this is a much better alternative to the intake manifold. Comparable HP gains w/o the loss of low end torque.
Old 07-18-2005, 08:23 PM   #14
B_w.
i thought higher flow headers are not required unless you are using FI. the stock headers are supposed to flow pretty well.
Old 07-18-2005, 09:17 PM   #15
EuroStyle
Your Ride: 92 325i
If you have a turbo you won't have a header style exhaust manifold, your exhaust will flow through a turbo manifold and into a down pipe.
Adding headers in adition to a super charger would be great.
Think of it this way, the more exhaust gases you can get out of your car the better. High flow headers are shaped and coated for more efficient air flow (simmilar to a cat back exhaust). Thus you achieve hp and trq gains.
Sorry
-Matt
intake question... ivopivo E36 21 11-21-2005 01:44 PM
