Old 05-04-2011, 10:26 PM   #1
foaxaca
foaxaca's Avatar
Your Ride: 1996 328is
Ext. Temp Sensor only reads -34 degrees F
1996 328is - The external temperature reading on the on-board computer readout is stuck on -34 degrees F. I'm thinking the sensor is bad. Anybody have an idea of where the sendor end is located? Obviously, it plugs into the back of the computer but is would be helpful to know where the sensor end is located so I can route it properly.
These external temp sensors must wear out at some point in German cars. I also have a 1993 Mercedes Benz 190E 2.6 Sportline Limited Edition (I know, I'm a sucker for punishment...) and the external temp sensor consistently reads 18 degrees low.
Old 05-05-2011, 03:50 AM   #2
ponyboy00034
Your Ride: 1992 325 is
its usualy under the drivers side headlight in vents under the car. you can reach it by kneeling in front of the car.
How to re-calibrate the ext. temp E36 NavyL7 BMW OEM Parts Department DIY's & FAQ's 5 08-11-2007 08:28 PM
