Old 07-11-2005, 06:14 PM   #16
brien4787
Title: DelTaco
Your Ride: e36
wtf no what?. ..... oem rotors are all that he needs..... why the hell would you pay more for something that isnt doing shit... haha it sounds like modding your car with bolt ons... kinda like exhaust... at least with exhaust you are getting a cool sound.. hahaha
Old 07-11-2005, 06:20 PM   #17
cainchapman
cainchapman's Avatar
Rate My Car: 126 / 340
Your Ride: 1995 540LE
Cross drilled crack between the holes. The holes are there to let that layer of hot gas that builds between the pad and the rotor out faster. Unless you are doing heaps of track days, it's just not worth it. BMW rotors are very good. As stated before, good pads, good fluid and braided lines will be everything you need for 99.95% of your usage.
Did you fit your front spoiler? It should have brake ducting to help cool your brakes. If that is not there, I'd recommend fitting them. Your rotors should also be vented ones, I'd expect.
Old 07-11-2005, 06:40 PM   #18
brien4787
Title: DelTaco
Your Ride: e36
not sure on the inline 6 brakes... but on my 4 the rears are solid, and the front rotors are vented
Old 07-11-2005, 08:02 PM   #19
jrhaile
Rate My Car: 114 / 340
http://cgi.ebay.com/ebaymotors/ws/eB...category=33564
this is the kit I'm going with. Hell of a deal if you ask me. Then I'm going to try and find some 330 calipers and throw those on in the future...
Old 07-11-2005, 08:22 PM   #20
EuroStyle
Your Ride: 92 325i
Originally Posted by Spieluhr
ok, thank you everyone, I will go ahead and purchase the stock OEM style rotors then. Thank you for your help.
Don't do it!
The perfect break set up for our style cars is from Bavarian Auto (this is my oppinion).
Here's what to get...
1. Bavarian Autosport Cross Drilled Brake Rotor Set - Front 170.00
2. Bavarian Autosport Cross Drilled Brake Rotor Set - Rear 170.00
3. Mintex "replacement" pads Front/Rear 100.00
3.5 OR Pagid Sport performance pads Front/Rear 110.00
3. Teflon Coated Stainless Steel Braided Brake Line Kit 125.00
5. Ate Super Blue Racing Brake Fluid 12.00
____________________________________________577.00
This is going to be my set up next summer, when I need new breaks.
Things to think about:
1. When you replace your breaks you should always replace your Brake Pad Wear Sensor Wire.
2. If you don't want to spend over 500.00 then cut out the Crodd Drilled rotors and get disc brakes.
3. Cross drilled rotors look sick behind rims
Old 07-11-2005, 10:04 PM   #21
brien4787
Title: DelTaco
Your Ride: e36
if you are going to pay more for brakes, go with bigger shit, dont buy stuff that is similar to oem and pay more, jus tmy opinion though
Old 07-11-2005, 10:26 PM   #22
Spieluhr
Title: ///M Driven
which is why JR is right in saying to get 330 calipers
Old 07-11-2005, 10:39 PM   #23
BMW328is
Your Ride: 1997 BMW 328is Boston Green/Sand Leather
E46 front rotors and calipers can be installed on our cars. Even the 330 rear rotors and maybe calipers? will fit once you trim the dust shield a bit.
Old 07-12-2005, 02:59 AM   #24
Spieluhr
Title: ///M Driven
Would it look stupid to just have the front brakes be power slotted? Because at Turner I can get front ATE gas slotted rotors for just $30 more.
Old 07-12-2005, 06:01 PM   #25
EuroStyle
Your Ride: 92 325i
I'm not 100% sure about this, but I think slotted rotors eat up your pads really fast.
Can any one else clarify?
Old 07-12-2005, 06:56 PM   #26
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 68 / 340
Your Ride: 1995 M3
I don't know from experience, but logically that would make sense. Slotted rotors bite off more pad to stop you faster...
Old 07-12-2005, 07:52 PM   #27
cainchapman
Yes, they do use pads faster (but not significantly). As you have pointed out, the reason for the slots is to grind the face more agressively than a standard rotor. Hence the reason to by Mintex 1166. I've had mine in more than a year now and they have heaps still left on them. Used for road & track.
Old 07-12-2005, 07:52 PM   #28
Spieluhr
Title: ///M Driven
makes sense. I don't want to do that then. As I am ceramic pads already don't last long.
Old 07-12-2005, 08:27 PM   #29
EuroStyle
Your Ride: 92 325i
hey man, if you have to replace your breaks and are only looking for slightly increased stopping power just put on SS brake lines, and use some super blue. That will be enough for street use.
Does anyone else agree?
Old 07-12-2005, 10:09 PM   #30
cainchapman
OK. Here is a quantified answer. NZ Autocar have just finished running a VBox on my car. The 100-0 (kph) was done in less than 31m. To put that in perspective, the new V10 M5 stops in 34m, an M3 CSL 32.55m, a Lotus Elise 111R in 34.6m an F360 F1 in 34.59m.
As stated, Mintex 1166 pads are the only real change to the standard BMW package. Brembo vented & slotted rears only. The tyres will contribute also, as they are also extremely important to the stopping distance and handling.
Braided brake hoses will only bring about a noticeable change if your existing hoses are tired and stretched. Again, mine are still stock.
For all of us who like to wast time at work projal147 Comedy Collection
21 02-07-2007 10:51 AM
mmmm brakes bitcore E36 31 11-16-2005 08:24 PM
4th time my AC has gone out (nws: language) bitcore E36 5 07-27-2005 11:06 PM
Time Travel Impossible komodo United Off Topic  **FOR MEMBERS ONLY** 5 07-26-2005 03:18 AM
poll: suspension or brakes? Spieluhr E36 40 05-11-2005 11:48 PM
