Old 07-02-2005, 06:43 PM   #1
///Menace328i
Your Ride: 1998 328i
Spark Plugs Upgrade soon...
I will be upgrading sparkplugs soon... Bosch or Denso Platinum... has anyone tryed these, how is your throttle response with these? How's ignition with either of these?
Redefining Ballerism!
Old 07-02-2005, 08:19 PM   #2
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
i hear Bosh platnium ae good, but ive never used them in my BMW. if i were u i might replace my plug wires as well depending on if there still the originals.
BTW: ur new sig kicks ass!!!
Old 07-02-2005, 10:53 PM   #3
jrhaile
Rate My Car: 114 / 337
stick with stock plugs...
Old 07-02-2005, 11:09 PM   #4
catalyst
Rate My Car: 197 / 337
Your Ride: 1994 325is
nice sig man...
Tripod with the hood open then with it closed?
Old 07-03-2005, 09:38 AM   #5
///Menace328i
Thanks... No tripod, and I did it on the fly... and it came out good...
Old 07-04-2005, 07:45 PM   #6
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
stick with the stock plugs. i have heard that different plugs might not function properly and reduce performance.
Old 07-04-2005, 11:31 PM   #7
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
I've actually heard the same.
Old 07-05-2005, 11:29 AM   #8
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
i actually love the plus 4's from bosch. I got a boost in performance with those and the the new bavauto performance coils. Worth the money. Not only did I lose the stutter, my car is accelerating faster than I can remember.
Old 07-05-2005, 01:42 PM   #9
Spieluhr
Title: ///M Driven
do not go with bosch platinum +4 or anything like that. You need Bosch COPPER plugs. go to www.autohausaz.com and they will have the plugs you need. I tried running platinums for a while and at first I noticed a difference but then they decayed really quickly. I have been using stock coppers for a while now and my car hasn't skipped a beat.
Old 11-19-2005, 06:00 PM   #10
defkon99
defkon99's Avatar
Rate My Car: 50 / 337
Your Ride: 1993 E36
so these are the ones huh .
Spark Plug; Copper; Dual Electrode; OE Plug
Pregapped for normal usage. $3.94
Old 11-19-2005, 07:31 PM   #11
TJsBimm
Rate My Car: 222 / 337
Your Ride: 97 328i
don't know what pulgs i had since i hadn't changed them, but the shop put in Bosch Silver........ car feels a little sluggish on performance but also had the fan clutch replaced at the same time so that might be it. Don't know but remember it being quicker.
Old 11-19-2005, 08:22 PM   #12
Spieluhr
Title: ///M Driven
yes defkon, those are them.
Old 09-07-2006, 10:47 PM   #13
kjprince
hey where did you find those plugs for under 4 dollars?
i have a 95 m3 and can't seem to find solid information on which plugs to use.
realoem, pelican parts, and autohauzaz all specify different plugs
Spark plugs Dudesky E36 21 10-21-2010 11:22 PM
Spark plug replacement & compression test DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 21 10-18-2010 10:22 PM
HID Upgrade Rooz Car Audio and Electronics 16 10-23-2005 09:15 AM
DO NOT go with Bosch Platinum +4 spark plugs billycuth E36 20 08-05-2005 12:17 PM
Upgrade Help!! komodo E36 25 06-16-2005 12:19 AM
