Old 03-09-2011, 03:16 PM   #1
diet
Your Ride: bmw coupe e36 1999
heating e36
hi guys i have a e36 99 digital climate. on full power doesnt seem that powerful through vents even tho motor is spinning fast cud this be my pollen filter? air onli seems to be loop warm aswell not hot and doesnt seem to make much difference where i direct the airflow its bin like this since ive had the car now bout 4 months but i hurd it cud be a sinple pollen filter causing this problem am i right?
Old 03-09-2011, 11:30 PM   #2
Manolito
Rate My Car: 337 / 337
Old 03-09-2011, 11:31 PM   #3
Manolito
Old 03-10-2011, 04:36 PM   #4
diet
okay i will buy one in 2weeks when i get paid and another thing my heater even when switched on the manaul mode it will lower the fan speed even tho on the diplay setting is the same then after a few minautes sometimes a while it will let me hav all my fan speeds back any idea what this cud be?
p.s mainly does it in cold whether but it is really annoying blower motor has alreadi bin replaced
Old 03-10-2011, 11:49 PM   #5
Manolito
The filter will run $10 to $15 on line depending on whether you get one with carbon. I use the cheaper ones.
From what I have read on forums like this one. problems with heater fan speeds usually trace to a problem with the resistor. That part is about $70 on line.
If the heater control unit goes altogether nuts on you, you can probably fix it for about $1
http://www.frontiernet.net/~papi/Clim_Ctrl.html
Old 03-11-2011, 11:06 AM   #6
diet
ok cheers i will update in a couple weeks if i change the cabin filter
Psychotronik's E36 M3 3.0 psychotronik E36 33 02-04-2011 02:20 PM
E36 Floorboard Lights Installed! Took All Day/Awesome pictures! delmarco E36 13 08-19-2005 07:31 PM
This is the E36 I am looking to buy... mpowerd E36 36 07-15-2005 03:07 PM
