Old 02-08-2011, 09:54 AM   #1
tauki
Your Ride: 1997 bmw 323 (m52)
no power uphill
hi everyone,I have these problem.When pushing accelarator padel soft the car will move normal & change normal.when pushing hard the car dont move fast,instead the rev count got stuck around 5000rpm.it does'nt go to next gear.no power at all espessialy uphill.I've checked vacume leak,but still.anyone with help please
Old 02-09-2011, 11:41 PM   #2
Manolito
Rate My Car: 337 / 340
The first suspect when someone complains of lack of power climbing hills is the fuel filter. The second suspect is the fuel pressure regulator. Instructions for replacing the fuel filter are here:
http://www.frontiernet.net/~papi/Filter.html
Usually when the fuel pressure regulator fails, either the vacuum hose has cracked from old age, or the the diaphragm inside fails and fuel starts leaking out through the vacuum hose to the intake manifold.
Old 02-10-2011, 06:42 AM   #3
tauki
Thanx man.I did change fuel filter,but stil.what do you mean by fuel pressure regulator.where do I find that?I'm thinking of replacing fuel pump.what do you think.'couse even if the car is standing & u rev it. it's respond is slow
Old 02-10-2011, 08:39 AM   #4
Manolito
Regulator should be attached to the fuel rail and should look something like these:
http://www.pelicanparts.com/bmw/cata...pg3.htm#item20
Also, be sure there are no air leaks into the air tube between the mass air flow sensor and the throttle body.
Old 02-11-2011, 08:03 AM   #5
tauki
Thanx man.My problem now is one,the regulator of my car is one unit with fuel rail to injectors all the way to fuel filter.So I can't get one from spares.In two weeks time I'll get fuel pump & let u know the result.Thanx again.
Old 02-16-2011, 10:24 AM   #6
tauki
I've changed regulator & fuel pump.there is a small improvement.Now I don't where to check again.Any boby with idea pls
no power uphill tauki E36 3 04-06-2010 11:27 PM
BMW releases free M Power app for the iPhone scooter BMW News And RSS Feeds 0 01-04-2010 09:30 PM
Upgrade To Power Folding Mirrors Complete E46 Pictorial Guide (Part 1) delmarco BMW OEM Parts Department DIY's & FAQ's 1 12-08-2008 07:24 PM
weird CEL... ivopivo E36 46 03-22-2006 01:22 PM
Microsoft Power Supply komodo Comedy Collection
1 07-13-2005 06:30 PM
