Old 02-04-2011, 04:32 PM   #1
Jetty
1995 325i flooded
I was told to pull the fuel pump relay and crank over engine to blow out the fumes. This is coming from a trusted mechanic.
Where is the relay? I know approximately... but which one is it specifically?
Thank you in advance.. Jetty
Old 02-19-2011, 09:25 PM   #2
Big Evil
Big Evil's Avatar
On fuel injected cars its even easier than that, put the gas pedal all the way to the floor and crank the engine. Holding the accelerator pedal at wide open throttle during start up puts the vehicle in "clear flood" mode and it switches off the injectors.
Old 02-20-2011, 09:43 AM   #3
Manolito
Rate My Car: 337 / 337
It is a lot easier to locate the fuse for the fuel pump relay than it is to locate the fuel pump relay. The cover on the fuse box will tell you which fuse it is.
It is tougher than one might think to identify which relay controls what. Alldata does a pretty good job of identifying them if you have access to that. Otherwise, you are pretty much stuck with manually activating different systems while someone puts their finger on the relays to see which one clicks.
Old 08-01-2011, 10:09 PM   #4
Jetty
Thank you for the information about the petal to the floor to go into flood clear mode.
Before I read your reply I pulled the fuse and it worked like a charm! I had to crank it over several times while being jump started. My battery was down. But! It worked!
Hope this helps some else. A mechanic told me they get cars towed in all the time and they are simply flooded.
Thanks again, Jetty
Old 12-19-2011, 03:23 AM   #5
reycycle70
Your Ride: '95 325I SEDAN
thanks for the flood clear hint. havent needed it but good to know.
Buyer tips for 1995 325i mckinney15 E36 11 08-01-2011 10:31 PM
1995 325i hesitaion Mtechnic325i E36 7 10-06-2010 03:27 PM
1995 325i question denise8509 E36 0 08-12-2010 07:11 AM
1995 325i won't start, was running great. new to site Jetty E36 20 12-15-2009 06:25 AM
FS: 1995 BMW 325i Addicted? Bmw Cars For Sale/Wanted 9 07-22-2005 07:37 PM
