Old 01-12-2011, 11:59 AM   #1
tauki
Your Ride: 1997 bmw 323 (m52)
auto transmission problem
Hi,everybody.I had these problem,sometimes while driving the auto trans sign pop's up,the I had to switch engin off for few seconds & on again,then is fine.Now lately it got stuck on 1&2nd gear & reverse avail.today it could not move at all.Any body with idea pls.I did top up transmission oil,but stil no movement.
Old 01-15-2011, 05:34 PM   #2
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
Recharge the battery and check output of your alternator, this is an electro-mechanically controlled transmission, so all external electrical connections also need to be clean and firm.
Old 01-16-2011, 10:19 AM   #3
Manolito
Rate My Car: 337 / 337
I concur with David. I have often seen threads on these forums where the first sign of a failing battery or charging system was quirky transmission behavior.
Old 01-17-2011, 12:57 PM   #4
tauki
auto transmission
Thanx man,My battery is new.when the engine runs,I get 14amps from the alternator.But I will check other external electrical connections.mechenic told me that the clutches are funished.I thought maybe its time for new one.what about faulty computer box?
Aftermarket Alarm/Remote Start, E46 bueras Car Audio and Electronics 41 03-04-2012 04:25 PM
E36 Transmission Stuck in 3rd gear thorntoncg E36 8 10-20-2011 04:29 AM
e34 1994 540i - transmission problem? Help aj77 E12, E28, E34, E39, E60 6 08-11-2011 07:14 AM
'95 E34 540 - auto trans speed sensor control - shifting problem trading10 E12, E28, E34, E39, E60 9 11-04-2010 09:02 PM
540ia transmission problem safcnz E12, E28, E34, E39, E60 1 09-26-2010 07:03 AM
