Old 06-01-2006, 03:55 PM   #16
defkon99
defkon99's Avatar
Rate My Car: 50 / 337
Your Ride: 1993 E36
E36/E46 Trailing Arm Bushing/Rear Subframe Tool - New Version
on backorder
Shit on back order!
Old 06-02-2006, 11:15 AM   #17
defkon99
defkon99's Avatar
Your Ride: 1993 E36
just been doinf some hardcore searching this is day 3. i found this think it will work ? i mean does this kit look like its got all the parts for remove/install?
http://cgi.ebay.com/ebaymotors/Musta...45110874QQrdZ1
Old 06-02-2006, 12:12 PM   #18
Rate My Car: 106 / 337
No.
Old 06-22-2006, 02:44 PM   #19
gkoutsis
Your Ride: 1998 320 Cabrio
Check on www.ebay.co.uk
Search for "BMW trailing" and you will find a guy from The Netherlands selling a tool.
Do you think its good?
Old 06-22-2006, 03:39 PM   #20
bitcore
bitcore's Avatar
I made one from home depot, worked like a charm
2 2" endcaps and some beefy ass allthread\bolts.
I drilled and airhammed the bushing out, so no press needed there...
Nice manufacturing there, I wish I had access to equipment to make stuff like this, A NICE tool like that sure does make things more helpful, ghetto tools work but usually end up tearing up things a little bit\being dangerous to limbs\face and are almost always a pain in the ass... But they usually involve a drill and a power saw so its sometimes fun >: )
Now if you could invent a tool to make rear wheel bearings easy and cheap.... That'd be sweet!
Old 06-22-2006, 06:26 PM   #21
^^^Ehh, as you may have read in the DIY that followed, the tool didn't work well for pulling out the old bushing, but it worked like a charm for installing the new one . . I made the legs a wee bit too wide
As for the wheel bearing tool, defkon bought one, and has offered to rent it out to members
Old 06-22-2006, 06:31 PM   #22
gkoutsis
I was referring to this tool....
http://cgi.ebay.co.uk/Special-Tool-r...QQcmdZViewItem
Somehow I think this is only for putting them back and not removing them....
Old 06-22-2006, 06:59 PM   #23
^^^No, that will also work for removal, just reverse the positioning of the tool.
Old 06-22-2006, 07:25 PM   #24
gkoutsis
Doesn't the bushing have a flange?
Old 07-05-2006, 12:42 AM   #25
gkoutsis
Small Update, that tool will not work for removal!
I thought by removing the flange on the original bushing, I could use it but I was wrong. The part which is suppose to push the bushing from the back is one mm thicker and it snugs in the arm when beeing used. I could have sanded the outer surface a bit but I just wanted to get over with it.
Fitting back was a breeze. Less than 2 mins
Old 07-05-2006, 04:49 AM   #26
Storamin
Storamin's Avatar
Title: Road Kill
dudesky my man... how much to ship it the tool to 15010?
removing is easy, just involves some convincing fitting it in... that's the difficult part!
Old 07-05-2006, 07:03 AM   #27
^^^Can't imagine it being more than 5 to 8 bucks. Just PM me with your address and I'll ship it out ASAP. Whatever it ends up costing, just throw the $$ in with the tool whenever you send it back, no worries.
Old 07-05-2006, 04:32 PM   #28
Storamin
Storamin's Avatar
Title: Road Kill
i did the right rear RTAB without any tool, and i will NOT be attempting the left in such a fashion!
Peake airbag SRS tool for RENT fujhonny Bmw Cars For Sale/Wanted 1 01-04-2006 10:18 PM
is this the SRS tool I need? Spieluhr E36 5 10-02-2005 06:48 PM
officially a tool Chris United Off Topic  **FOR MEMBERS ONLY** 12 09-15-2005 09:07 PM
E30 Reset tool ///Menace328i Bmw Cars For Sale/Wanted 0 05-22-2005 12:04 PM
Fault codes - got a bavauto diagnostic tool billycuth E36 4 05-06-2005 01:18 AM
