Old 09-05-2010, 10:21 AM   #1
estpaul
Your Ride: 1996 316i compact
e36 compact ceiling fabric
hi guys, recently ive started to notice that the fabric on the ceiling has come detatched in the corners. id like to stick it back up there, but i dont want there to be glue stains on the fabric. Also i dont want to take the whole thing off and re stick it, as i live in a flat (apartment) and i dont have a garage where i could do the work.
i was thinking that maybe i could get some syringes, and fill them up with some sort of glue (all purpose or Uhu) and inject through the fabric in multiple locations to get it back up there. any ideas or recomendations?
Old 09-05-2010, 01:14 PM   #2
gldfshkpr
gldfshkpr's Avatar
The key words here are use sparingly. I used some all purpose fabric glue that worked great. In the places I put it on too thick, it shows through ("stains"). The places I glued were the edges. I have spots like you have where either a syringe or cutting a slit would be an option. Kinda think a syringe small enough to put down the correct amount wouldn't be big enough to push the glue. Let us know how it goes. Maybe somebody here has a better solution. This issue seems to be fairly common.
Peace,
Kirk
Hang up and drive.
Old 10-02-2010, 11:51 AM   #3
gc325is
Your Ride: 325 1995
The foam is old and deteriorating. The whole cover will eventually fall down. Glue works on the edge for a year until the center fails. I used a thin layer of white Elmers glue after scraping the old foam.
e36 compact rear speakers daboni Car Audio and Electronics 0 05-17-2010 02:03 PM
e36 compact rear speakers daboni E36 0 05-17-2010 01:59 PM
E36 Compact OnBoard Computer championc E36 0 11-14-2006 05:15 AM
This is the E36 I am looking to buy... mpowerd E36 36 07-15-2005 03:07 PM
