Cam Software
As you guys all know already, I'm about to do an M50 manfold install and s52 m3 cams. I currently have a conforti shark injector. After this new work, will I be running lean or rich? Do you think the conforti software will be fine, or do I need new software? If so, where do you recommend I get it?
Thanks. |
I don't know if you will be running lean or rich, but you will need new software. You can get software at understeer or eurosport for about $650 i think.
Tms most likely has a chip that will cover those mods, as they are pretty common.
Edit: i mean shark injector in your case. |
hasnt JR done all that? talk to him im sure he has all ure answers
| All times are GMT -5. The time now is 11:39 AM. |
