Old 08-30-2010, 03:06 AM   #1
Mtechnic325i
Mtechnic325i's Avatar
Rate My Car: 275 / 329
Your Ride: 1995 BMW 325i w/ Mtechnic Body
1995 325i hesitaion
hey guys. i got a problem and i just cant seem to figure it out. i have a 95 bmw 325i and the engine has a hesitation mainly in the lower rpm up to about 3k, and after that sometimes it runs fine, then starts again around 5.5k sometimes. my brother in law (got the car from him) says he just changed fuel pump, fuel filter, water pump, i cleaned the maf, new intake. i just cant figure it out. some said it could be the cats but i dont know. any help is appreciated thanks
Old 08-30-2010, 10:43 AM   #2
Big Evil
Big Evil's Avatar
Cleaning the maf can cause premature failure of it. However if it did it before and after that wasn't your problem. Everything else being replaced SHOULD eliminate them as well but don't count them out just yet, I've seen new parts fail right out of the box. However again if it did it before and after I'd be looking at other possibilities before throwing more parts at it.
What kind of vacuum does it pull at idle? Have you had the vac system smoke tested to look for leaks? Are there any check lights on and/or does the vehicle have any codes?
Old 08-30-2010, 01:47 PM   #3
Mtechnic325i
there are no check engine lights. all the part were changed but no change. i did not check the vacuum lines. how do you test them?? thanks
Old 08-30-2010, 03:58 PM   #4
Big Evil
Big Evil's Avatar
First get a vac gauge and see what the engine pulls at idle (manifold vacuum) that will tell you a lot.
Second to test the vac system you need a smoke machine and you pump smoke into the system to looks for leaks. There are specialized machines for it, however a party fogger with some homemade rubber bits will do the job nicely as well.
Does the intake whistle or "hoot" at all while running?
Old 08-30-2010, 04:24 PM   #5
Mtechnic325i
alright. will a regular boost/vac gauge work to check the vacuum at idle. and what do you mean by whistle or hoot? is there a video or something i can look at? and thank big evil for the help really appreciate it.
Old 08-31-2010, 10:47 AM   #6
Big Evil
Big Evil's Avatar
Yes on the gauge. If you don't know what I'm referring to on the sound then your car isn't doing it (which is good).
Old 09-15-2010, 12:52 AM   #7
Mtechnic325i
i checked compression and all where about 200psi. i know its high but all of them where the same. what else good be causing this hesitation? thanks
Old 10-06-2010, 04:27 PM   #8
Big Evil
Big Evil's Avatar
What kind of vac does it pull at idle (what does the needle do? steady or fluctuate?) and did you smoke the system to check for leaks?
Buyer tips for 1995 325i mckinney15 E36 11 08-01-2011 11:31 PM
1995 325i question denise8509 E36 0 08-12-2010 08:11 AM
1995 325i won't start, was running great. new to site Jetty E36 20 12-15-2009 07:25 AM
1995 325i - Starting Issues scrichy84 E36 15 03-22-2006 06:58 PM
FS: 1995 BMW 325i Addicted? Bmw Cars For Sale/Wanted 9 07-22-2005 08:37 PM
