Old 06-23-2010, 01:23 AM   #1
pink craven
Your Ride: 98 e36 m43 engine
Angry Advice please
I own a 98 E36 M43 engine 16i compact, I'm having a new engine fitted today and the engine come from a manual car and is going into a auto car, Is the crank the same and can you just swop the flywheel and so on . I've removed the front end for the garage and what so of time should it take for then to remove/swop engines and re-enter the engine/gearbox and finish the fitting, I'm going to do the re-build of the front end. many thanks, and come on ENGLAND, IF NOT eNGLAND THEN USA
Old 06-28-2010, 07:39 AM   #2
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
The part numbers can be found here http://www.realoem.com just see if the part numbers are identical, if not ring the parts counter at your local dealership and ask if they are interchangeable.
Bmw Advice mlongo2005 7 Series (E23, E32, E38, E65, E66) 9 11-14-2010 01:03 PM
advice installing front struts on a '92 525i jeffcloud1960 Tire, Wheels And Suspension Forum 0 01-09-2009 02:39 PM
NEED ADVICE ON 328ci joeblow4ya BMW General Discussion 3 09-29-2007 12:03 PM
Need advice - want to buy 98 528i patrickjoseph E12, E28, E34, E39, E60 2 05-30-2006 06:29 AM
Need advice on mods Rooz E36 30 08-18-2005 04:00 PM
