Old 05-29-2010, 10:28 AM   #1
tauki
Your Ride: 1997 bmw 323 (m52)
car dies as it reach normal temp
hello everybody.my car starts fine in the morning.the sooner temperature reaches 12'oclock,it cut off & it wont start until after 2 minutes or more.the engine turns but not firing.after it start again it will not cut off for that day.when it is warm the idliling goes up & down.I've chacked the vacume leak but still.anybody with help pls
Old 06-04-2010, 02:36 PM   #2
kazamali
Your Ride: 99 M3
It almost sounds like when your car goes into "closed loop" mode (i.e. starts using the data from the MAF,ICT,ECT, O2's, etc) it finally kicks.
Is your check engine light on? Sounds like one of the sensors above is going out and you just need to figure out which one. It is strange that the car wont' start for a short amount of time because if a sensor goes "hard" bad, the computer will just ignore it, but if it's just "soft" failing, many wierd things can happen. What happens if you disconnect your MAF?
I say this in all of my posts, but a simple OBDII sofware package will give you actual sensor readouts so you can pinpoint what's going on.
Old 06-10-2010, 03:28 AM   #3
tauki
bad sensor
thanx man,I changed crank sensor & now the car is running great again.thanx
Old 06-10-2010, 02:23 PM   #4
kazamali
Your Ride: 99 M3
Cool! Was that a guess? Or was there something that finally made it the obvious culprit?
Old 06-11-2010, 12:57 PM   #5
tauki
yes
I first changed camshaft sensor & it was doing samething,I then changed crank
You Might Be a Ricer If.... komodo Comedy Collection
20 11-08-2006 11:06 AM
Just Dropped My Car Off komodo E36 37 06-28-2005 02:16 AM
Laptop or pay off car... trade in or keep? Addicted? United Off Topic  **FOR MEMBERS ONLY** 16 06-25-2005 02:07 PM
Rate My Car Has Gone Live!! komodo Site Feedback 70 05-20-2005 07:28 PM
Huge Problem..Car Shuts Off Speedinfusion E36 15 05-04-2005 11:32 AM
