Your Ride: 1993 325is
Driver Side...Rear Axle half shaft
hello,
Just did my driver side rear wheel bearing...and for some reason the axle doesn't seem to want to go back into the hub...can anyone tell me how easily this should go back into the hub...and/or suggestions on what I should be doing to get the axle re-connected to the differential.
Your Ride: e36 m50/m3 turbo 1994
if its the diff end ive found thay normally go back one way as when i did e46 m3 dff oil seals had same problem if the other end then clean the spline with a wire brush an put hi temp coppr grease on it should slide in mate.........IREE
After doing that, give it a couple of thumps into the bearing until the threads come through and then you can GENTLY use the axle nut to pull it the rest of the way in.
