-   -   Dent in rim (http://www.unitedbimmer.com/forums/e36/1797-dent-rim.html)
Dudesky 06-14-2005 06:38 AM
Dent in rim
Any tried and tested methods for fixing a dented rim? I have a 3" flat on the edge, it's aluminum alloy. It seems to ride fine, just wanna get it back to shape. Potholes at 70mph . . :nono
TIA, __Dudesky
komodo 06-14-2005 09:16 AM
I took it to Kauffman Tire and they shipped it off to some other company. Took them like 3 days and cost me $100. :dunno
Antiburn 06-14-2005 11:16 AM
Piece of wood and a hammer. If its on the inside try a adjustable wrench and bend it back with that. Its not reccomended to beat your rims with a hammer beucase it suppoustly weakens them but thats a way to bend your rim back.
Dudesky 06-14-2005 11:55 AM
$100 is a lot . . I guess I'll try the block & hammer method. If I screw it up, then I can pay the hundred :doh
528man 06-14-2005 12:00 PM
sorry to hear about that. i hate pot holes.
Dudesky 06-14-2005 12:04 PM
Yeah, you'd think it was important to fix on a 2 lane highway bridge with no shoulder.
komodo 06-14-2005 01:06 PM
Around here if you hit a pothole and it causes any damage to your car, you're supposted to pull over immediately and get a police officer to come out and write up a report. If the police officer says it was indeed the pothole that caused the damage, the city will write you a check for the cost of repairs on your car. (then they'll fix the pothole, haha)
94bmw325i 06-14-2005 01:21 PM
What??? That's awesome Komodo :rock
RealBmw 02 06-14-2005 03:49 PM
if you are going to attempt to beat your rim back in shape, just be careful and don't try to go to far with it. If it is a very large dent, I would just pay the money to fix it cause most likely you will just do more damage than good, and then it might never be able to be straightened correctly.
komodo 06-14-2005 03:51 PM
That's very true. If you do it wrong, it could cause uneven wear patterns on your tires and ruin them.
Dudesky 06-14-2005 04:45 PM
Here's a shot . .
http://files.unitedbimmer.com/ub.c/D...6/rim_dent.jpg
It looks like mostly lip that was damaged, and hopefully it won't be too hard to coax back into shape. Definitely won't go crazy with it though.
catalyst 06-14-2005 07:23 PM
ouch thats probable going to be more than 100.. cause the bend is on the outer face of the rim, meaning its gunna need to be repainted after its straightened. A local guy here does straightening for 50-75 if its an inside bend, and 125-150 for straightening and refinishing.
Dudesky 06-14-2005 07:32 PM
No, it's hard to tell from the pic I guess, but the paint stops at the end of the spokes. From there to the edge is just milled & polished.
94bmw325i 06-14-2005 09:06 PM
Probably gonna cost at least $100.
Antiburn 06-15-2005 08:12 PM
Thats an easy bend to bend back. I suggest finding something hard to beat on that has the same angle % as the rim so you cna beat it back perfectly round. You could always get a measurement and cut a 2 by 4 into the shape.
