Old 04-28-2010, 01:45 PM   #1
justinaj
Your Ride: 1998 323i
Question pls help!!!!
hi
can anyone pls help, i have a 98 2.5 which is suffering with bad misfiring probs. it only happens at full temp and will continue untill i stop and let it cool, it cuts out at low revs and has no power until i take it over 3500 when it levels out a bit. spark plugs new, no coil breakdown issue and injectors are clean... im thinking a.m.s. or idle valve?? plus can it run with the a.m.s. disconnected?
would really apreciate any help. thanks
Old 04-28-2010, 03:48 PM   #2
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
Hook the car up and read the engine diagnostic codes. There are too many variables to just start swapping parts in the hope of rectifying the problem without reading the fault codes.
Old 04-30-2010, 10:42 PM   #3
kevzep
Your Ride: e36 316i
Hi, how are you?
Whats an A.M.S?
Not familiar with that engine but it might be worth cleaning your iacv.
Does it give you trouble starting off from cold?
Auto wont shift up, exp & solutions pls scooters 7 Series (E23, E32, E38, E65, E66) 15 11-30-2010 06:10 PM
WTB: A 2003 or 2004 M3- pls read further... asindc Bmw Cars For Sale/Wanted 9 04-21-2006 08:30 AM
Ahh Help Me Pls.. jrhaile E36 8 07-18-2005 01:34 AM
ZKW's coming, hlp needed pls Rooz E36 43 06-18-2005 08:54 PM
VIN check pls zenon United Off Topic  **FOR MEMBERS ONLY** 6 06-05-2005 08:37 PM
