Old 03-20-2010, 07:36 PM   #1
dickiele
Your Ride: 96 e36
96 E36 Radio/heating problems
Hello,
I'm new on this site, sorry if i posted this in the wrong forum. I'm having problem with my radio and theclimate control My radio does not having any sounds even when the volume is cranked all the way up. My heating system keeps switching itself off and on. Please HELP me!
Thanks in advance!!
Old 04-06-2010, 07:50 AM   #2
C Sean Watts
Name: C Sean Watts
Your Ride: 1997 328is and others
Originally Posted by dickiele View Post
Hello,
Thanks in advance!!
Do you have the electronic climate control or mechanical? I'll guess and say the electronic - and the CCU has failed. It will need to be replaced since it's not 'user serviceable' unless you are in a very well equipped electronics repair shop.
IF you have the premium audio system, the external amp unit may have failed or blown a fuse.
Take some pics and post them - it'll help.
Old 04-07-2010, 12:06 AM   #3
Manolito
Rate My Car: 337 / 337
Climate control repair for most common failure is here:
http://frontiernet.net/~Papi/Clim_Ctrl.html
Radio could be several things. I have two '97s, one with HK sound and the other with standard sound. The HK system has given a lot more trouble. Right now the volume control is whacked in the head unit and it has four blown speakers in the doors.
Can you provide more description of the way it is behaving?
Old 04-07-2010, 07:48 AM   #4
C Sean Watts
Name: C Sean Watts
Volume control is a common failure. It can be fixed but you must be careful about it. You need to take it out and use some plastic safe cleaner for potentiometers (and other electronics) and hopefully it's not too late.
How to remove the rear seat? E36 328 96' Bluz Car Audio and Electronics 4 08-31-2010 12:41 AM
e36 Clutch problems - release point hahaohwell E36 1 03-01-2010 08:34 PM
Problems with radio antena of an e36 325i 325i_GT Car Audio and Electronics 12 10-25-2009 03:38 PM
bmw e36 m3 convertible problems ozzieman E36 0 10-18-2009 06:24 PM
