Old 03-16-2010, 05:22 AM   #1
tauki
Your Ride: 1997 bmw 323 (m52)
o2 sensor
Hi everyone,can anybody tell me how do I know faulty sensor & a faulty vanos
Old 04-06-2010, 08:23 AM   #2
C Sean Watts
Name: C Sean Watts
Your Ride: 1997 328is and others
Two completely different animals.
The O2 sensor isn't truly "faulty" until you you get a MIL (check engine light) BUT, with age and miles it becomes slower until (what's known as the duty cycle) spends more time running outside of ideal mixture and the engine computer goes into default mode. That costs you fuel and power.
One of the signs of VANOS failure is a diesel engine sound, or "marbles in a can" coming from the VANOS unit. If you use only synthetic oil and change it on time, you often will not get this, but you will notice a loss of torque below 2500-3000 rpm. If you step on the gas below 2500 and let it climb WITHOUT downshifting and it feels like you got 'extra power' above 3000 rpm, your VANOS is not working as efficiently as it should.
Old 04-07-2010, 01:52 PM   #3
kevzep
Your Ride: e36 316i
How many O2 sensors on '95 525i ??? M50 volvodefector79 E12, E28, E34, E39, E60 4 08-03-2009 04:45 PM
O2 sensor values? IBIMMER E12, E28, E34, E39, E60 0 12-13-2007 12:44 AM
AA o2 sensor sims... ivopivo Vendor/Dealer Comments & Supporting Vendor Announcements 4 03-25-2006 05:26 PM
Potential O2 Sensor Problems Rooz E36 15 06-08-2005 09:54 PM
