Old 02-24-2010, 07:50 PM   #1
JoshsE36
JoshsE36's Avatar
Your Ride: 1993 318i 4dr 5sp
Post E36 Window Switch light replacement
Not sure if any one else has had their widow switch light/bulb go out, if so here is a part number for that bulb/light to be replaced. I found the DIY at the following link:
http://www.bmwe36blog.com/2008/10/31...tch-light-diy/
The bulb replacement is from Radio Shack, catalog # 272-1092, they come in a set of 2. (Micro Lamp).
This bulb is a bit smaller than then OEM type, but works just as well. I also painted it with red nail polish & it realy turned out good. Can't even notice any light differnce. Hope this info helps.
Old 02-25-2010, 03:25 AM   #2
user1
Rate My Car: 328 / 329
Your Ride: 1995 bmw
very nice, thanks.
Old 03-13-2010, 03:36 PM   #3
macneil
Your Ride: 92 325i
I got a couple burnt out actually, thanks.
Old 04-10-2010, 09:43 PM   #4
gc325is
Your Ride: 325 1995
I just opened my switch for another problem, There was a red led for the back light. Car is a 1995 IS. Watch those metal inserts, mine fell out and the switch stopped working.
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 31 11-02-2011 07:28 PM
Backup Light Switch DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 9 05-31-2011 09:27 PM
E36 power window problem techmike E36 7 05-15-2011 07:45 AM
Power window switch replacement mtudude33 E46 1 03-16-2011 03:40 AM
330ci window switch njjeter E46 2 07-21-2007 05:11 PM
