Old 02-19-2010, 10:06 PM   #1
hahaohwell
Your Ride: 96 328is
e36 Clutch problems - release point
hey guys i have a 96 328is.
the release point for my clutch has always been a little past halfway (where it should be). but a couple days ago it changed to only about a 1/4 way...
so i only press the clutch pedal down a 1/4 way to change gears... i know this will only get worse to the point where i cant properly ease into gears.
does anyone know what could have caused this or how to fix it?
i have a new clutch and flywheel on her with only 15000km on them
about 2 months ago i got a full brake fluid flush and rebleed, could this have had an impact since this is also the clutch fluid?
i do not beat this car up i drive it nice and as far as im concerned im pretty good at driving standard.
this happened once before and so i replaced the clutch, to find the old clutch disc still had 50% to it...
so now im stumpped.
any ideas will help
thanks
Old 03-01-2010, 09:34 PM   #2
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
The clutch hydraulic circuit is very simple, either it had air in it or you have a failing master or slave cylinder (if one fails you are better off repairing/replacing both as they suffer identical wear). If they are leaking, you initially get a full stroke as you push the clutch in, but fluid rapidly bleeds past the leaking seals, causing the clutch to begin releasing by itself. Unless you have xray vision, from the drivers seat it feels like the clutch release point requires less pedal travel - this is not the case. Even though you may be able to change gear without pushing the clutch right in, do not do it as it will be at the expense of premature clutch wear and possible transmission damage. Leaking seals are often only internal, so you may not see external fluid leaks. By the way, this is not a theoretical explanation, I learned the hard way several years ago.
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 31 11-02-2011 07:28 PM
E36 Clutch Replacement DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 23 12-05-2010 10:52 AM
Bought an e36, two small problems.. help? danoman94 E36 9 11-22-2010 01:28 PM
bmw e36 m3 convertible problems ozzieman E36 0 10-18-2009 07:24 PM
clutch problems.. crisby325i E21, E30 4 06-03-2007 10:44 PM
