Old 02-18-2010, 08:43 PM   #1
fxoaxaca
Your Ride: 1996 328is
Question 1996 328is - Is this an EWS II problem?
Car ran fine until yesterday night. On the way to work in the morning, temp and fuel gauges stopped working and brake light circuit error appeared on OBC. Looks like that is fuse related. Car kept running fine. No check engine light or any other symptom.
Main problem is that in the evening, car would not start. Insert key, turn ignition and all dash lights go on, radio goes on but NOTHING happens - no cranking, no dimming of lights, no relays clicking. NOTHING! I've read about the EWS II system and how if for any reason the key is not recognized the DME does not get the "OK to start car" signal and nothing happens when you turn the key. Has anyone experienced this with a similar vehicle? Has anyone had to fix this?
Thought it might be a fried DME but I read that even if the DME is fried, the car will at least crank.
Old 02-19-2010, 10:52 AM   #2
fxoaxaca
The car will not crank even if I try to jump start it.
Blower final state resistor - Where is it? 1996 328is foaxaca E36 1 05-18-2009 11:25 AM
328is problem, runs weird - Vacuum hose leak? something clogged? peterkdenny E36 4 02-16-2008 11:27 PM
ews help on 320 to 328 e36 conversion desperate 4 help E36 1 04-03-2007 01:08 PM
Location of EWS II control module singring E36 2 01-09-2006 05:54 AM
CARFAX please!!! Turbodefrost United Off Topic  **FOR MEMBERS ONLY** 6 06-27-2005 01:31 AM
