-   -   3.23 Lsd (http://www.unitedbimmer.com/forums/e36/1741-3-23-lsd.html)
komodo 06-11-2005 01:22 PM
3.23 Lsd
I've had a suggestion to get a 3.23 LSD diff for my car... but right now mine stock has a 3.91, so wouldn't I LOSE torque in that conversion, or is there something I'm not understanding about diffs?
EuroStyle 06-12-2005 08:53 AM
You don't have a 3.91, you have a 2.91. And yours is an open diff as opposed to the limited slip diff. Trust me, if you want quicker acceleration you want a 3.23 from an m3.
Rooz 06-12-2005 09:18 AM
Originally Posted by bad man working
E36 Dif Ratio:
328i manual = 2.93
328iA = 3.07
328iA USA = 3.91
M3 = 3.15 Limited slip
Originally Posted by 93 325i
The larger the ratio the faster the acceleration between gears, but the overall top speed of each gear is reduced. For instance a 3.91 ratio produces neck snapping acceleration, but isn't practical for highway use- the overall top speed is reduced but it will get you to top speed a hell of a lot quicker. YOu can get a used 3.15LSD for about $400. Anything higher has to be custom built and are about $1500. They are not too bad to install- this can even be a DIY if you have the courage. Performance wise a 3.46 LSD and JC chip has been documented to shave at least a second off your 0-60 time
Edit: A custom LSD is the next best thing to do outside of forced induction to improve acceleration. If your like me and rarely go over 100mph this is somehting to surely look into.
hope it helps
komodo 06-12-2005 11:23 AM
Gotcha. Can someone explain the difference in limited slip and an open diff? I've always wondered that but never known. :)
witeshark 06-12-2005 01:03 PM
Limited slip, (in the case of my car uses disk like a clutch) prevents a traction-less wheel from uselessly spinning, open diff allows this wheel spin, frustrating in slippery situations, but slightly more efficient in terms of friction ;)
B_w. 06-12-2005 01:38 PM
i upgraded to a 3.23 lsd from an open 2.93 and it made a huge difference in traction and acceleration. a very worth while upgrade for a manual, but not to sure about it for an auto.
jrhaile 06-12-2005 01:50 PM
not worth it in an auto.. stick with what you got...
Torque 06-12-2005 04:19 PM
In lamest terms, open diff = one wheel burnout; LSD = both.
I think you should go for a 3.23. Yeah, it will probably be loud and as un-economical as shit on the highway, but who cares.
Rooz 06-12-2005 04:36 PM
US Auto cars have it perfect 3.91 is has good as it gets for Auto E36's
If you feel your car doesn't "accelerate" quic enough, drive a truck or a normal car for a day, and when you get behind the wheels of your car, you'll see what I mean.
94bmw325i 06-12-2005 04:56 PM
So an LSD is the same as a posi?
komodo 06-12-2005 11:40 PM
How would a 3.91 open vs a 3.23 LSD differ if the car is an auto or manual? How would that change things?
jrhaile 06-13-2005 12:56 AM
yes possi is the same thing as LSD...
it changes your geating ratio'...s with a 23 you're top end will be higher in speed but and you might gain a little more grip from the beginning... I would take that money and use it for going 5spd personally.. an auto with a LSD is pretty much useless imo.
bitcore 06-13-2005 07:25 AM
Yes but if you have enough power to make the inner wheels spin and loose traction during a turn, then an LSD would be benificial now wouldn't it?
Open diffs suck, they are no fun at all.
yes, LSD==positraction. I prefer to say LSD since positraction is a ford\chevy term.
Read this: http://auto.howstuffworks.com/differential.htm
Viscus LSD's are awful for preformance (as you can see, there is no SOLID connection, same thing that makes automatic transmissions suck [the torque converter]). Quaife sucks for racing since once one wheel reaches zero traction, the torque bias suddenly becomse 100% to that wheel, basically an overly complex open diff. Clutchpacks are great for racing & preformance and there is no loss of power from the clutches. Nascar uses a detroit locker diff that locks the rear axles together completely under load, Great for foreward traction, but suck for turns, not really important to them is it? :P
E36Bimmer 06-13-2005 08:17 AM
If you have a 3.91 now, going to a 3.23 would be worse. I have only looked into this for 5 speed manuals. Im guessing you have a 4 speed auto, so your tranny gearing ratio is way different than a 5 speed manual. Im thinking that this would reek havoc on your auto tranny if you played around with the gearing ratios.
bitcore 06-13-2005 01:23 PM
It wouldn't cause havoc, it would just shift differently. It calculates when to shift based on RPM, current speed, and gas pedal positions. If it does suck somehow, you can always go into steptronic mode. The automatics don't downshift until the RPMs are somewhere below 1,000 so they wont accidentally over-rev unless you go into steptronic and it's lower gear RPM prediction is too low due to the ratiochange, so I guess just be careful when doing that.
I heard from someone at a BMW dealership that they reset my "computer" and my transmission will "re-learn my driving style" when it was in for some reapairs, so it may very well automatically detect each gear's sped limits based on whatever gearing ratio it's hooked up to.
