Old 01-29-2010, 02:37 PM   #1
AlpineWeiss
Your Ride: 325 is
Spark and Fuel yet no start
Hello all, im experiencing problems with my 94 325is. One day i sat in the car and it did not start. I know the fuel pump works because the plugs are wet, and i also here it working with a automotive stethoscope. I tested spark yesterday by removing one of the coils, and pluging a wire with a spark plug on it, it was properly grounded to the motor. I saw a blue spark several times as i was cranking it, it was dark so I know i saw it for sure. I dont understand why my car doesn't start. If there is fuel going to the motor, and there is spark what else can it be? I also replaced the ignition switch, and put another DME in, that I had. Still doesn't start...its a mystery. My next option is to put a new crank sensor in, as that seems to be the culprit in many cases. However, from my understanding the crank sensor if not operational, there would be no spark or fuel, yet I have both. Any suggestions im stumped....thanks alot...
Old 02-01-2010, 03:34 PM   #2
AlpineWeiss
Your Ride: 325 is
Does anyone have any idea?
Old 02-01-2010, 07:18 PM   #3
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
Read this link http://www.pelicanparts.com/BMW/tech...de_Reading.htm and pull the diagnostic codes for your car.
Old 02-02-2010, 11:59 PM   #4
AlpineWeiss
Your Ride: 325 is
There are no codes.....because there is no light on....I finally got it started it seems it was flooded some how...pulled the plugs and dry out the cylinders using an air hose. It starts up now. But what can cause this flooding problem? A faulty regulator?
Old 02-03-2010, 06:30 PM   #5
karime302
Your Ride: E30 M3
+1
Old 03-13-2010, 02:55 PM   #6
macneil
Your Ride: 92 325i
One time i had the same problem and all it was was my negative battery cable wasn't connected tight. I cleaned it and tightened it up and it started right up..
Spark plug replacement & compression test DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 21 10-18-2010 10:22 PM
e30 problem need help MaxBoostE30 E21, E30 7 01-27-2010 12:58 PM
New to me, '87 325. Yep, No start mooware E21, E30 4 11-23-2008 03:16 PM
E30 won't start - grrrrrrrr! geodanker E21, E30 11 11-07-2007 06:17 PM
Help! No spark, No fuel ixgarry E36 0 09-24-2006 12:33 PM
