Old 01-19-2010, 03:14 AM   #1
vaneverc
Your Ride: 1993 325is
Noise coming from the rear driver side wheel/axle??
I have had the back left wheel bearing replaced in my 1993 325is. However, now I have this horrible noise that sounds like its coming from the driver side back wheel. I have replaced the back shocks and shock mounts and to no avail the sounds keeps getting worse. At some points before the car has been moving/warmed up...it almost sounds a little bit like a grinding noise. Most recently the faster U go the loader it gets...almost unbearable in the cabin of the car. Is it possible this could be the wheel bearing again? And how bad is it for me to keep driving it like this?
Any input would be greatly appreciated...thanks
Old 01-19-2010, 08:49 AM   #2
3050rpm
3050rpm's Avatar
Since you've replaced the shocks and shock mounts, it certainly sounds as if it's the wheel bearing, and you're describing what I experienced with my car last year, again on the driver side in the back. Your situation is also sounding rather critical (mine was getting that way and the mechanic told me not to wait on it), so get that thing replaced, I think if a bearing does fail it could lead to seizure of the wheel, not good.
Old 01-19-2010, 09:29 AM   #3
vaneverc
Thank U for the response I really appreciate it. One last quick question...should I replace both back wheel bearings at the same time? or can I just do the one?
Thanks again...
Old 01-19-2010, 09:41 AM   #4
3050rpm
3050rpm's Avatar
I asked the same question of the fellow who did the work on my car, and he said it's not necessary to do both (unless of course the opposite side is showing symptoms too). Seeing as you've already done one on your car, I'd say you're okay just doing this one.
rear noise, E30, mzbmw325i E21, E30 20 04-07-2010 10:12 AM
Rear End Noise - 2006 325xi Ebby1600 E90 11 12-07-2009 10:37 PM
Rear end Noise and Shifter issue chaswr7 Z Series (Z3, Z4, Z8) 1 07-24-2009 10:57 PM
Rear one side lower than other side isBMW E36 8 05-21-2009 08:09 AM
Left side rear wheel clunking noise ?? jonni325 E36 10 04-13-2007 07:34 AM
