Old 01-18-2010, 10:56 AM   #1
Anchorsmash
Your Ride: 318 is
Is it bad to add anti-freeze to my car without mixing it with water?
I added coolant to my BMW 318Is without mixing it with water and was wondering if it can cause any harm to the car. My mechanic said it's better to add it without mixing it but i want to double check.
Thanks for any feedback
Old 01-19-2010, 08:37 AM   #2
3050rpm
3050rpm's Avatar
It depends on the type of coolant you were using, pre-mix or not. As the name implies, the pre-mix formulations are already set to pour into the system, the non- requires the addition of water. In your present circumstance, you're probably okay, but see below...
There are a few important things to bear in mind. First, use a modern formulated brand of coolant, I believe BMW requries one without borates, silicates, or phosphates. Second, optimal coolant performance comes with a 50-50 mixture, which is something you don't have to worry about with the pre-mix types. Third, if you do add water, use distilled water, not tap. Fourth, if you haven't done it in the past three years, you should thoroughly flush your cooling system, meaning radiator AND engine block, and put in new stuff.
Old 04-06-2010, 11:33 PM   #3
Manolito
Rate My Car: 337 / 337
3050rpm's advice was excellent. I would add a couple of notes:
1) I presume you added only a pint or two, so if anything, you most likely brought a typically over-lean coolant mix closer to 50:50. You certainly did no damage.
2) Speaking from the bitter experiences of myself and others who have posted, it is best to bite the bullet and use BMW branded coolant. You can get it on line much cheaper than at the dealer. Avoid DexCool coolants.
Old 04-07-2010, 04:49 PM   #4
C Sean Watts
Name: C Sean Watts
Your Ride: 1997 328is and others
This can NOT be overstressed. I would add not just avoid it, DO NOT USE IT AT ALL!!
Damage photos
Lawsuit over dexcool damage
Settlement and more damage info.
Old 04-07-2010, 05:46 PM   #5
kevzep
Your Ride: e36 316i
Also put the heat up full when you are filling the sytem. I'm not sure if this applies to aircon models but it cant hurt.
Car Shaking REALLY bad Mercenary(FH) E36 19 05-19-2012 12:24 AM
The Laws of a Ricer komodo Comedy Collection
24 01-22-2008 04:54 PM
You Might Be a Ricer If.... komodo Comedy Collection
20 11-08-2006 10:06 AM
DTP car show pics (Anti 56k) DEATH2000 Video and other Multimedia 6 06-15-2006 04:36 PM
Water vs. Coke EnvyM3 United Off Topic  **FOR MEMBERS ONLY** 14 03-25-2006 12:07 AM
