Old 06-10-2005, 02:04 PM   #1
Rooz
Rooz's Avatar
Rate My Car: 7 / 329
Your Ride: 2003 M5
ZKW's coming, hlp needed pls
OK, my ZKW's with DDE ehanced are coming in tomorrow, and since I know a bunch of you have these I was wondering if you had any tips for me on the installation, and am wanting to do the "parking light delete" so that only the DDE's will light up when I put them on parking light, any help would be most apreciated!
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 06-10-2005, 04:26 PM   #2
Spieluhr
Title: ///M Driven
contact JR about the parking light delete. or im sure they have seomthing on the e36 DIY site
Old 06-10-2005, 04:31 PM   #3
delmarco
delmarco's Avatar
Rate My Car: 224 / 329
Your Ride: 2001 330i
I will post something for your early in the morning.....
the most important things are you unplug the battery during installation, and change the fuses before you even turn the lights on. (this is if they are going to have HIDs)
Old 06-10-2005, 04:54 PM   #4
Rooz
Rooz's Avatar
Your Ride: 2003 M5
Who's JR?
Thx Del, I'll be looking for it, no they are ellipsoids...
Old 06-10-2005, 10:13 PM   #5
jrhaile
Rate My Car: 112 / 329
I'm JR :P Are you getting hids? If you're not getting hids, this is a very simple installation...
no need to replace any fuses or even unplug your battery... I've done the install on several diff cars without any problems as nothing that is electrical is running...
basically for the headlights, take out your old ones, pretty straight forward.. wire up your new ones and plug them in... if it doesn't come with a wiring diagram for the 4 wires, just keep guessing until you get it right haha...
as for the parking light delete, just put a piece of electrical tape over one of the bottom connectors on the actual bulb itself.. you have a 50/50 shot of getting it right :P if it's not right, take it backout and put it on the other one haha.. very simple. good luck and must have pics when done
Old 06-10-2005, 10:15 PM   #6
Rooz
Rooz's Avatar
Your Ride: 2003 M5
Not getting HIDs, but for the parking light delete, I actually want to wire the DDE as parking lights.... I guess I'll need to transfer the wires from the parking lights to the DDE's so that way I shouldn't get an error code on the check control thingy. I've done this for my licnese plate lights, they don't light up but nothing show on the check control because I transfered their wire to ym rear parking lights..
I hope Fedex doesn't let me down and actually brings them in tomorrow, otherwise Umnitza shall hear a peace of my mind
Thx for everyone's help, so JR you said taking the stock headlights is pretty straight forward?
Old 06-10-2005, 10:31 PM   #7
jrhaile
umm 3 bolts that are easily seen up front and 2 on each side.. might have to remove the plastic cover thingy that's in the center/front of the engine bay... also you need to take out your corners first too.. I just took the grey wire and spliced it into the grey/purple wire going into the corners... this also does a cool effect if you have an alarm with lighting... like on my girls car, when she hits her alarm, the halos flash at the same time as the corners :P
Old 06-10-2005, 10:33 PM   #8
Rooz
Rooz's Avatar
Your Ride: 2003 M5
since you did your parking light delete the electrical tape way, does it show up when you hit check control?
Old 06-10-2005, 10:40 PM   #9
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
Man my car supposedly has an alarm in it that is unplugged. Car came with remote but splace I took it to said for them to fix it would cost same as a new alarm. Where can I find one that will make my lights flash james?
Sorry to jack thread Rooz. Good luck with the ZKW's!
Old 06-10-2005, 10:41 PM   #10
Rooz
Rooz's Avatar
Your Ride: 2003 M5
You probably have a fried module, bcs I had similar problem and needed to buy a new module
Old 06-10-2005, 10:41 PM   #11
jrhaile
no never had an error on the OBC... the bulb is still there and it reads fine so no OBC error, don't worry.
Old 06-10-2005, 10:42 PM   #12
jrhaile
you have to go aftermarket Nick to get your lights to flash I think.. the ones I did this on have aftermarket alarms...
Old 06-10-2005, 10:47 PM   #13
Rooz
Rooz's Avatar
Your Ride: 2003 M5
Yeah, getting a new module wasn't worth it, I wish I would have gone aftermarket, if only I knew
Old 06-11-2005, 11:45 AM   #14
Rooz
Rooz's Avatar
Your Ride: 2003 M5
they are here
Old 06-11-2005, 01:12 PM   #15
delmarco
delmarco's Avatar
ROOZ!!!!!
Can You Imagine!!!!
Your lil' 328is will be this beautiful at the end of the day when you get your ZKWs in there!!!!!!
Holla!
Post pictures buddy!!!!!!!
