Old 12-24-2009, 03:25 AM   #1
mesteptoe
Your Ride: 1995 BMW 316i
Question Spinning ignition barrel
The key on my 1995 (E36) now goes round and round in the lock. I have seen a few notes about extracting the barrel and presumably, if I do that, I could get a replacement. However, what are the chances that the steering lock is also damaged? If it is do I need to put it back - I think that part is expensive.
All suggestions welcomed about the best thing to do.
I have been quoted £62 to replace the barrel (not too bad) but £272 to replace barrel and steering lock.
Thank you.
Graham
Old 12-24-2009, 02:03 PM   #2
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
This is a very common problem with E36's. Just replace the ignition barrel or repair it like I did (see http://www.unitedbimmer.com/forums/e...el-repair.html ).
Old 04-07-2010, 12:48 AM   #3
Winter
Winter's Avatar
Your Ride: 97 alpine white/black manual 328i
happens sooner or later
Seems that there is this plastic break off tab installed just in case somebody wants to try and start your car with a screwdriver, ( not sure how true that story is but it works for me). The tab breaks off anyway leaving you with a spinning barrel hopefully not leaving the car in the on position forcing you to stall it. Some people drill a hole and stick a screw in there to act as the pin. Others replace the barrel, and break the same pin two years later. Youtube has videos showing how to fix it. I've found that its much easier to fix if it hasnt totally broken yet, and just spins once in awhile. To those with the intermitant spin around, fix it now before its too late and adds much to the suck factor.
GET OFF YER ASS AND DRIVE!!
Spinning Ignition barrel repair David Mc E36 12 10-05-2011 10:00 AM
help.. starter motor spinning out of control V-tecKILLAH E36 3 11-05-2006 10:00 PM
Pickled corpse tumbles out of rum barrel EnvyM3 United Off Topic  **FOR MEMBERS ONLY** 20 05-05-2006 03:34 PM
Plasma Ignition System Rooz E36 25 03-15-2006 10:58 PM
Need DME Ignition Transistor singring E36 1 12-15-2005 10:28 AM
