Old 10-30-2009, 05:52 AM   #1
insanity
Your Ride: E36 2.8
Central Locking
Hi I am fitting a TOAD alarm system to the car and having a little trouble with the central locking control form the alrm unit. Can anyone tell me is it it a positive trigger or negative trigger system. Or which wires I attatch to the system. Eveything else I have working fine. This is my olnly hold up any help woi=uld be appreciated.
Insanity
Old 05-31-2010, 06:01 AM   #2
littledragon
Your Ride: 1995 316i
Hi, wish I could help, I'm stuck with exactly the same problem. Have you had any luck yet? Thought it would be easy but looks like I'm gonna have to call a pro in unless someone on here can help? Cheers.
Old 09-07-2010, 02:44 PM   #3
johnf
Your Ride: 6/96 318is
I hope that's not a Cane Toad.
The IR remote lock and unlock inputs to the central module are both positive trigger. To double-lock the car, you pulse both simultaneously: most people use a couple diodes. I believe you will find your central module, either a central locking module (ZVM) or a central electronics module (ZKE), behind the glovebox.
This PDF may be helpful.
E36 Remote central locking query garyclarke1962 E36 3 06-02-2010 09:52 AM
E36 Coupe central locking problems quill E36 3 04-09-2009 01:55 PM
central locking system sydwin X Series (X3, X5,X6) 0 10-17-2008 09:24 PM
central locking....getting stuck.... Numark318i E21, E30 5 01-24-2006 10:54 AM
Central Locking Bubba E21, E30 4 12-29-2005 12:29 AM
