Old 10-16-2009, 07:35 PM   #1
chutan
chutan's Avatar
Your Ride: 1992 e36
Diagnostics problem
Hi fellow bimmerheads,
I have a problem getting my car diagnosed. When they hook up the computer it doesn't produce any codes. Even doing the manual ( driver side ) diagnostics won't work.
It has some rough idling after i step my accelerator too much and i want to know if there's a problem on its sensor.
I have a 92 e36 325i
Thanks,
Luke
BTW this is my first post and its really nice to be in a company of e36ers
Old 10-22-2009, 05:41 AM   #2
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
Check to make sure that your DME is clean and dry, all fuses are good, then read this link http://www.pelicanparts.com/BMW/tech...de_Reading.htm
Old 10-22-2009, 03:52 PM   #3
Big Evil
Big Evil's Avatar
How old is your fuel filter? Any gas seepage anywhere? Vacuum leaks don't usually pop codes if they're small, that's also a possibility. Do you have anything to smoke test the system with?
Old 10-28-2009, 06:28 AM   #4
chutan
chutan's Avatar
Your Ride: 1992 e36
@ David .... thanks for the link.....i will try again the OBD 1 diagnosis thru the dashboard. Last time my mechanic was not able to list down the codes...not sure if he knew those blinking check engine light were the codes.
@Big Devil ...... fuel filter is about 3 years old. Are you referring emission testing on the smoke test? Had it tested last December and it was within normal limits
Old 10-28-2009, 10:20 AM   #5
Big Evil
Big Evil's Avatar
The smoke test I was referring to is when you pump an inert smoke into the vac system of the car to look for leaks. Shops do it with a big fancy machine that basically amount to a party fogger.
If you have flashing lights though you may have a code(s) and we can help more effectively.
523 E39 problem vialle E12, E28, E34, E39, E60 0 01-21-2009 06:31 PM
325 brake light problem fgmx Lighting 2 02-01-2008 01:52 PM
e36 convert problem Butcher E36 3 09-07-2007 05:24 PM
BMW 320i Gas Problem rOMa E36 5 06-27-2007 02:40 AM
