Old 09-27-2009, 04:23 PM   #1
Sheltie
Your Ride: 1995 318i
e 36 ecu problem
My 1995 318i has the bmw rain problem. The computer got wet. help. Won't start no spark no engine check light.
Old 09-27-2009, 06:40 PM   #2
3050rpm
3050rpm's Avatar
It was my understanding that the plenum drainage problem was successfully dealt with in the '95s and newer, I sure hope so because I've got one. In any event, I've heard that all is not necessarily lost, letting the ECM dry out can do the trick.
Old 09-27-2009, 09:54 PM   #3
Sheltie
The 1995 318i was manufactured 9-94 and this may account for the difference.
The car has a lot of the parts and motor pieces from the early car.
I successfully dried out the ecu. drove it and now another problem of no start . May be the ecu gave it up.
Old 09-28-2009, 04:09 PM   #4
3050rpm
3050rpm's Avatar
Given the date of manufacture, you're right, the modifications may not have taken place in time for your car. Still, I'm not sure it's the ECU, as I believe you did dry it out, you were able to drive the car for awhile after that, and now no dice? How did it run while it was running? Would hate to see you plunk down money for a new unit if the cause is otherwise, obviously.
Old 09-30-2009, 02:53 AM   #5
Sheltie
The car ran like nothing had happened. Now its dead. The car ran out of gas- I filled it up and it would not start. The next day it fired up. - thought problem and everything would be fine . wrong- it died a week later. I have replaced the pump, relay and fuses -nothing.
no codes from dash, no spark- starter works fine. Everything works- locks, lights, radio, starter except no running engine.
I took out the ecu and opened it up, dry as a bone- seams to be ok. no way to check it.
Old 09-30-2009, 05:01 PM   #6
Big Evil
Big Evil's Avatar
Unfortunately it's old enough that there really isn't much out there to test that specific ECU with (real old DIS or GT1 maybe). Fortunately though it's old enough that a replacement can and will be pretty cheap Try shopping around, I got a new ECU for an E30 of mine for like 60 bucks on ebay with a performance chip. Worked great, just pay attention to the sellers feedback if you go that route though ;-).
Old 09-30-2009, 08:23 PM   #7
3050rpm
3050rpm's Avatar
I was going to say, I'm flat out of ideas, not that I'm replete with them to begin with, but Big Evil's suggestion is the next logical step. Good luck.
ecu problem..realy need advice fourtwenty E36 5 01-20-2008 04:24 PM
M42 318 Wont Start. ECU problems? Numark318i E21, E30 3 10-14-2007 04:08 PM
e36 convert problem Butcher E36 3 09-07-2007 06:24 PM
ECU location maximk2 E36 3 05-27-2007 01:57 PM
Time for a new ECU DME POS_BMW E36 8 07-10-2006 04:08 PM
