Old 09-05-2009, 11:58 AM   #1
goforit
Your Ride: 318i
Question Starter removal???
Hi,
How do I get at the bolts to remove the starter on my '94 318i 5-speed manual? I can get at one from the bottom no problem but where's the other one and how do I get a wrench on it?
Thanks!
Old 02-06-2010, 10:52 PM   #2
gldfshkpr
gldfshkpr's Avatar
Hi there. Did you ever figure out where the top bolt is located?
Peace,
Kirk
Hang up and drive.
Old 02-07-2010, 10:06 AM   #3
karimMsalama
Your Ride: BMW M5 VW MK2
go to a work shop
Old 02-07-2010, 10:40 AM   #4
goforit
Your Ride: 318i
Yes, and it was a pain but do-able. I did it in the driveway. Requires Small hands and Patience!!!! If you need the info and the tools required let me know.
Old 02-07-2010, 03:35 PM   #5
gldfshkpr
gldfshkpr's Avatar
Yes please! I think I can locate the upper from the bottom by feel. I can just barely get a finger on it. When I come at it from the top, I can't seem to find it. How did you do it?
Peace,
Kirk
Hang up and drive.
Old 02-07-2010, 07:05 PM   #6
karime302
Your Ride: E30 M3
thanks for this nice info
Old 02-07-2010, 07:48 PM   #7
goforit
Your Ride: 318i
I managed to remove the old starter by only removing one end of a coolant line from the firewall. I tried approaching it is several ways but this is what worked.
I ground down the side of a 16mm ring wrench to fit on the nut from above the car and used a number 12 torx socket with the extensions shown to remove the bolt from under the car. It took some patience but is very do-able. It would be nice to have a lift but I did it in my driveway with both driver's side tires up on blocks.
I placed a lit maglight near the bolt head so that I could see the general location from below the car. To get the socket in place took me getting in and out from under the car several times. It would have been much easier with a buddy.
In the pictures the black extensions are wobble extensions.
If you look hard at the pictures taken from above you can just see my socket on the bolt head.
When placing the wrench on the bolt you can use a light and look through in under the manifold an through the wires while inserting the wrench over the back of the engine.
My car is a '94 5-speed 318i
Not sure if I'm allowed to do this or not but Ican't find my pictures again.
http://forums.bimmerforums.com/forum...d.php?t=558140
Does a Starter Give Warning? 3050rpm E36 4 12-13-2006 02:00 PM
help.. starter motor spinning out of control V-tecKILLAH E36 3 11-05-2006 10:00 PM
No Battery Voltage to Starter singring E36 2 01-09-2006 09:20 PM
Bad starter? catalyst E36 11 11-09-2005 01:47 PM
starter replaced..but problem brien4787 E36 1 05-12-2005 04:59 AM
