Old 08-25-2009, 04:48 PM   #1
briang0
Your Ride: 1994 325i
94 325i conv ABS light
I have a 94 325i where the ABS light come on as soon as I turn the key. I took it to the dealer and they said the wheel sensors were good but the module was not processing the signals. I replaced the ABS module, both relays, checked the fuses in the relay box, and replaced the ABS pump and I still have the light. Not sure where to go next. The car runs great except no ABS.
Old 03-16-2010, 07:20 PM   #2
briang0
Turned out to be the left front wheel sensor was open. Not sure what the dealer was looking at when they said that the sensors were good.
Old 04-02-2010, 03:11 AM   #3
chutan
chutan's Avatar
Your Ride: 1992 e36
Is the wheel sensor the same as the brake sensor?
Old 04-02-2010, 09:12 AM   #4
briang0
Yes, I did mean the abs sensor. You can ohm them out should be between 600 - 1.2k ohms if good. In my case it was open. Hope this helps.
Old 04-02-2010, 11:52 AM   #5
chutan
chutan's Avatar
Your Ride: 1992 e36
hi again...is abs sensor the same as brake pad sensor? my cousin's e36 has the same problem as yours. Diagnostics from the dealer doesn't show any problems from its computer but ABS light is turned on.
thanks for the fast response
Old 04-02-2010, 04:48 PM   #6
briang0
The break wear sensor is a separate cable that mounts into the brake pad. This will show a different warning light on the dash board. There are several things that could cause the abs light to come on. There are 2 relays under the hood (red and grey) there are several fuses that can cause it. Also the ABS pump can cause the light to go on too. I would check all the fuses first, Then the relays they are about 25.00 each. If you have the bently manual that would help.
Old 04-03-2010, 07:34 AM   #7
chutan
chutan's Avatar
Your Ride: 1992 e36
thanks bro...will do
ABS light Smittythefe E36 0 02-04-2009 02:14 PM
Abs Light On Help gavsav1 E46 0 01-29-2009 03:05 PM
abs light on MBD506 E36 3 03-21-2008 09:08 PM
E30 325is ABS light is on dev6315 E21, E30 8 03-04-2008 06:55 PM
e36 abs idiot light bbimw E36 3 08-07-2007 08:16 PM
