Old 08-13-2009, 02:43 AM   #1
robt
Your Ride: 318i se 1998
abs light
hi all...im a new member and i must say what a goodun!...heres my 1st post and problem.ABS light is on permanently,ive cleaned sensors etc,new bearings on front.ive heard that it could be a relay,if so any1 know which one it is ?...cheers all
Old 08-13-2009, 09:44 AM   #2
3050rpm
3050rpm's Avatar
Could you be more specific on what you mean by "cleaned the sensors"? There is an electrical connection in the cable that's fairly easy to pull apart and check, but there's also the connection in the wheel hub that should be inspected, but is a bit more difficult to undo. I haven't heard of a relay failure, although I suppose that's possible, my guess is that if cleaning the connection I referred to above doesn't do the trick, then the wheel speed sensor is in for replacement.
Old 08-13-2009, 10:10 AM   #3
robt
thanks for reply...the "bits" ive cleaned off are in the wheel hub,i did them when changing bearings (and the connectors in wheel arch)
Old 08-13-2009, 10:18 AM   #4
scooter
scooter's Avatar
Title: Administrator
Rate My Car: 294 / 337
Your Ride: 99m3
its usually a bad speed sensor that causes the abs light to come on.
Abs Light On Help gavsav1 E46 0 01-29-2009 03:05 PM
E30 325is ABS light is on dev6315 E21, E30 8 03-04-2008 06:55 PM
e36 abs idiot light bbimw E36 3 08-07-2007 08:16 PM
Back to the dealership! yearly inspection, ABS light, new pads&rotors$$$$ delmarco E36 14 07-07-2005 09:42 AM
ABS check light came on!!! please HELP!!!! delmarco E36 9 07-06-2005 08:27 PM
