Old 07-31-2009, 06:43 PM   #1
bigxcam
Your Ride: 1996 328I
Overheating issues
The overheating thing
Ok here's an update. Was installing new thermostat and overtightened bolt on housing. Busted a big chunk off the aluminim housing. Steeler has the plastic replacement. Shall i go with the plastic, or try again with aluminum and just be damn carefull this time? i went ahead and pulled the h20 pump, it is metal. The connection fopr the fan has a little play though, any thoughts on that. I mean a teeny tiny bit of play.
now the crazy part. The hose coming off top of radiator going to thermo housing was bone dry, turned white inside. also the hose coming from bottom of radiator going into the otherside of thermo housing, bone dry and white. The thermostat was also white. but when I removed h20 pump there was fluid that came out. I drove this sucker home last night like that, it didnt overheat again. Is the hoses being dry like that what happens when the thermostat is locked shut? Have I been driving around without a flush from the radiator. thats crazy! Its been holding up like that for probably 500 miles that ive put on it since I bought it a few weeks ago. IS it wierd that the water in the radiator never made it to the engine but still blew out when it overheated, i mean what overheated it if it never flushed throught the engine..bizzare. My fan works fine I did check that.
thanks,
Cam
Old 07-31-2009, 06:52 PM   #2
scooter
scooter's Avatar
Title: Administrator
Rate My Car: 295 / 329
Your Ride: 99m3
moved to the proper subforum.
posting in the right section will probably net you much better results.
Please Help me and My 318is overheating and very low idle Serge E36 2 03-10-2010 08:38 PM
E39 Overheating jay E12, E28, E34, E39, E60 10 03-04-2008 09:08 AM
Overheating neo66 E36 10 06-19-2007 01:08 PM
Overheating problems! Oh my! digismack E36 24 01-07-2007 12:05 AM
im having hardware issues... e30boarder Geek Chat 15 08-08-2005 04:09 PM
