Old 07-29-2009, 11:52 PM   #1
bigxcam
Your Ride: 1996 328I
steering wheel rattle at high speeds
my 96 328i has steering wheel rattle at high speeds. I can actually turn the steering wheel a degree or 2 to the left or right and get out of the rattle. wheel bearing?
thanks,
Cam
Old 07-30-2009, 10:10 AM   #2
3050rpm
3050rpm's Avatar
Could you help with some further details? What speed or speed range? Does it seem to be coming from outside or inside the passenger compartment? Does the steering wheel shimmy or is it smooth yet the rattle seems to come from the steering column? My quick guess is that this is a case of wheel balancing, but more remotely could be engine or transmission mounts needing replacement.
Old 07-30-2009, 11:28 AM   #3
bigxcam
Wheel rattle
I'm going to get a wheel balance and an alignment as it pulls to the right a bit. I'll let yah know if that helped.
thanks again,
Cam
Old 07-30-2009, 09:25 PM   #4
Big Evil
Big Evil's Avatar
Bad bearings should show up at the alignment, depending on how bad they are they most likely won't be able to align it. And yes more details please
Old 08-10-2009, 03:18 PM   #5
youngunn
Your Ride: 325i
i had the same problem, it was just a wheel bearing fix. when i would go over a certain speed and turn the wheel wouldn't turn as stiff and raddle.
Old 08-14-2009, 04:59 PM   #6
bigxcam
It ended up being the wheels I got off craigslist. I got burnt. 2 bent rims, flat spotted from probably a pot hole. DOH!
Detailing techniques and products... ivopivo Detailing and Cleaning 2 09-15-2009 02:51 PM
BMW e46 steering wheel adaptor dilemma badazz3001 E46 0 01-28-2009 04:12 PM
Steering Wheel Issues 525mike E12, E28, E34, E39, E60 1 03-26-2008 06:24 PM
DIY: Add M3 steel guage rings to E36+ Remove Steering Wheel & Cluster. (pics) delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-09-2005 01:05 PM
steering wheel cruzin 323is E36 17 04-26-2005 07:18 PM
