Old 07-23-2009, 07:55 AM   #1
Serge
Your Ride: 318is
Coolant Temp sensor dilemma
Peake research tool threw up the error for coolant temp sensor and knock sensor, bought new knock sensor and temp sensor, installed the lot, knock sensor code disappeared after battery disconnect for 24 hours but the coolant temp sensor is still there e4 from memory, anyhow what are the symptons for a dead/dodgy coolant temp sensor? and most importantly how do I get it to go away? is there a way to clear codes apart from disconnecting the battery? car is a 1993 318is.
Old 07-23-2009, 09:48 AM   #2
3050rpm
3050rpm's Avatar
It may not be the sensor per se that is faulty so much as the connection to the sensor. Surface corrosion that comes with age could be giving a faulty reading (happens with my car, a '95) so unclip the connection, clean it up a bit, and see if that does the trick. As to how/when codes disappear, some seem to go after the battery is disconnected for 10 mins., some for 2 hours, some overnight, I wish I had a definitive answer.
E39 Faq.... Dan E12, E28, E34, E39, E60 63 12-02-2010 10:05 PM
Coolant Leak - Expansion? chris3896 E46 8 08-25-2009 11:04 PM
Coolant Leak, Fuck (long post) dinan540 E12, E28, E34, E39, E60 13 03-22-2008 01:25 AM
coolant flush for oil in coolant alanaszkler E12, E28, E34, E39, E60 1 11-16-2007 11:18 AM
Coolant Level Mercenary(FH) E36 5 10-27-2006 03:37 PM
