Old 07-22-2009, 02:00 AM   #1
Serge
Your Ride: 318is
Overheating Please Help
I have replaced the bloody head gasket, new gaskets all round etc... the car overheat when idling, no white smoke nothing at all, I noticed when I rev the bugger the needle drops back to centre, bring it back to idle and the needle pegs up... I have a new thermostat, belts and water pump, with new hoses the whole 9 yards... obviously the coolant isn't circulating properly or fast enough... any input would be great. Sere.
Old 07-22-2009, 08:42 AM   #2
3050rpm
3050rpm's Avatar
Did those gasket replacements include the timing chain gasket and the crankcase gasket? Has the entire cooling system been flushed, engine block as well as radiator? Could be an air pocket.
Old 07-28-2009, 08:35 PM   #3
falcon900
Your Ride: 1997 328i
There's a procedure for bleeding the system. When I've performed maintenance on the cooling system it does take time to bleed the air out.
Off the top of my head, heater on full hot and open bleeder screw and let coolant circulate until air has passed and top off coolant.
Old 07-30-2009, 09:12 PM   #4
Big Evil
Big Evil's Avatar
Might have to raise the nose of the car while doing it too, sometimes air pockets can be a bitch. Other option is to vacuum fill the system, radkit plus is the tool you use, it'll pull a vac on the system and then fill, eliminates the need for bleeding.
Bmw Overheating Problem -please Help souljahslim E36 7 04-25-2011 06:45 PM
E39 Overheating jay E12, E28, E34, E39, E60 10 03-04-2008 09:08 AM
Problems with overheating gannando E36 8 01-11-2008 10:16 AM
Overheating neo66 E36 10 06-19-2007 01:08 PM
Overheating problems! Oh my! digismack E36 24 01-07-2007 12:05 AM
