Old 07-10-2009, 06:25 PM   #1
that90
Your Ride: 1996 bmw 328iS
Squeaky Clutch WTF!?!?
YO WTF!!!! Every time press down or release my clutch pedal on my 328iS it squeaks both inside the car and out. This shit is annoying!! (especialy when theirs a girl in the car) What the hell do i do about this?????
Old 07-11-2009, 11:38 AM   #2
Big Evil
Big Evil's Avatar
Try lubing the pivot points on the pedal etc.
Old 07-14-2009, 06:29 AM   #3
lightflyer1
Your Ride: 98 328ic
Replace the clutch pedal bushings with Delrin. There are kits out there for this.
Old 07-18-2009, 10:55 PM   #4
JoshBMX
Your Ride: 1998 323i Convertible
Or it could be a sign that your clutch is starting to go bad. Mine started a while back with just making noise when I let out the clutch which I thought was just the pedal. Now, once the vehicle has warmed up it will squeal constantly whilst the clutch is depressed, so it is progressing further and will have to be replaced in the future. I just try to drive like a responsible person in the meantime while Isave up a little coin for a clutch and flywheel combo. Keep an ear out because your symptoms are EXACTLY as mine were. Hope that helps bud!
Best wishes,
Josh
Old 11-25-2009, 12:53 AM   #5
Jonathan073
Your Ride: 1992 325is
According to http://www.unitedbimmer.com/kb-e36-c...faults-faq.php a squeaky clutch pedal is a pretty common problem, and like lightflyer said, you probably just need to replace your clutch arm bushings, you can get them cheap here:
http://www.uucmotorwerks.com/html_pr..._arm_bushings/
and another 15% off this week if you use the coupon code "15TURKEY"
E36 Clutch Replacement DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 23 12-05-2010 09:52 AM
Clutch fluid 3050rpm E36 0 03-01-2009 01:04 PM
*NWS* Wtf!?!?!?!?!?!!?!? RSF5 United Off Topic  **FOR MEMBERS ONLY** 14 03-25-2007 01:22 PM
FAQ: How the clutch operates Dudesky BMW OEM Parts Department DIY's & FAQ's 10 07-09-2006 11:25 AM
Clutch Install pics! 56k...nah devinwwu E12, E28, E34, E39, E60 4 08-04-2005 04:34 PM
