Old 05-26-2009, 01:45 AM   #1
Dathaeus
Your Ride: 1997 328i w/sports package
E-brake cables?
I've had some advice to check on the dust shield making this rubbing noise... however I think my parking brake is getting worn and my mech told me I need a new one and a spring kit... maybe the old springs are not disengaging enough and it is still rubbing.... anyways I need to know besides the pads and spring kit, so I really need to get 2 cables also, or can I just use the old ones? I know on a bike cables need to be replaced like every year or two for avid riders... here is a list of my cart items from Pelican Parts (seemed like the best deal.. thanks guys!):
Emergency Brake Cable, 2 required, each, BMW E36 3 Series, Brand: Genuine BMW
$40.75
Emergency Brake Spring Repair Kit, 328i/is/iC (1996-99) Brand: Ate
$14.50
E-Brake Shoe, Set of four, 328i/is/iC (1996-99) Brand: Pagid
$36.50
Subtotal: $91.75
1997 328i w/Sports Package
5 speed manual
120,000 miles
Front: 17" (225)
Rear: 17" (245)
Answerway.com
Old 05-26-2009, 08:55 AM   #2
3050rpm
3050rpm's Avatar
I rather doubt you need the cables, but the spring kit and the pads yes, the pads wear, and the parts included in the spring kit, particularly the adjusting sprocket, are subject to corrosion and are best replaced. I really haven't heard of any problems with the cables, unless there's been severe abuse.
Old 05-27-2009, 02:59 AM   #3
Dathaeus
Thanks.... I figured as much bec no one else told me I should get those, but knowing for sure is nice!
5 speed manual
120,000 miles
Front: 17" (225)
Rear: 17" (245)
Answerway.com
DIY: E39/E36 Brake Pad Replacement mullethunter3 BMW OEM Parts Department DIY's & FAQ's 10 02-02-2012 08:00 AM
DIY Brake Pad Change nick_318is BMW OEM Parts Department DIY's & FAQ's 6 08-25-2011 10:23 PM
BMW Inspection Rooz BMW General Discussion 21 03-14-2006 02:10 PM
E30 Brake Pad Changing Procedure nick_318is BMW OEM Parts Department DIY's & FAQ's 6 10-14-2005 06:36 PM
Quality Brake Package (rotors, pads, lines) Spieluhr Vendor/Dealer Comments & Supporting Vendor Announcements 2 08-28-2005 03:05 PM
