Old 05-20-2009, 07:15 AM   #1
isBMW
Your Ride: 1998 318is
Rear one side lower than other side
Hi guys
Quick one my car 98 318is saloon, the rear driver's side is lower than on the other side anybody knows why?
Measured on level surface drivers from outside of rim to wheel arch 12cm
and on passenger side 13.5mm
could spring have sagged?
Old 05-20-2009, 07:15 AM   #2
isBMW
sorry 13.5cm
Old 05-20-2009, 09:56 AM   #3
3050rpm
3050rpm's Avatar
Could be a spring, but also could be a structural failure in the shock mount area, a weakness in the E36 design brought about from hard use, especially on the track, if this area is not reinforced. Pull back the lining in the trunk to see if things are okay.
Old 05-20-2009, 04:49 PM   #4
Big Evil
Big Evil's Avatar
Yup, 3050 is right. What your describing could be a sagging spring but is most likely a bent/damaged component. Assuming your tire air pressure is good who did you loan the car to that might have curb checked it?
Old 05-20-2009, 04:56 PM   #5
scooter
scooter's Avatar
Title: Administrator
Rate My Car: 294 / 337
Your Ride: 99m3
being that its only 1.5cm could it be a spring pad?
Old 05-20-2009, 09:00 PM   #6
Big Evil
Big Evil's Avatar
It's certainly possible, your best bet is to have a shop the does suspension work and alignments check it out (unless you have the equip and training to do this, springs can be dangerous). If you take it to a shop though make sure the guys know beemer. They're not to different from normal stuff but they do have their kinks. Have you taken a look under the car and done a visual? When did you first notice it and what may have happened just before? Most likely that'll give you your answer.
Old 05-21-2009, 01:26 AM   #7
isBMW
Thanks guys will do that and keep you posted on what the problem was!!
Old 05-21-2009, 01:31 AM   #8
scooter
scooter's Avatar
Your Ride: 99m3
when you measured was your ebrake on? that will make one side on the rear sag.
Old 05-21-2009, 08:09 AM   #9
MBD506
Your Ride: 1995 325is and 1994 325i
rusted spring
Maybe the spring got rusted and it broke, that's what happend to mine.
E36 Rear trailing arm bushing replacement Dudesky BMW OEM Parts Department DIY's & FAQ's 19 06-01-2011 11:02 AM
DIY: Install Rear Shades on your E36/E46/E34 BMW! delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-26-2007 10:41 AM
Rear End Handling Issue Please Help cult E36 17 09-18-2007 01:01 PM
Remove my rear Lower arm link Gercheusoj Tire, Wheels And Suspension Forum 3 06-20-2007 03:45 AM
Left side rear wheel clunking noise ?? jonni325 E36 10 04-13-2007 07:34 AM
