Old 05-13-2009, 02:45 PM   #1
tils1975
Your Ride: bmw 316i E36 1998
E36 1998 BMW 316i - Climate Control
Hi, I have a problem with my climate control, basically the power is not very strong, using the control panel I increase the power but very little happens, at full power it is as if I am only on half power, I have heat and A/C fine very hot and very cold but because no power its doesnt seem to work well, not sure what the problem is, has anybody had this problem and can anyone help or give me advice, awaiting your help.
Old 05-13-2009, 04:47 PM   #2
Big Evil
Big Evil's Avatar
Define no power, lack of airspeed/volume out of the vents? Could be a clogged microfilter, clogged intake under the front cowling, excessive resistance in the power wire to the fan motor or the fan motor giving up the ghost. Could also be the squirrel cage slipping off the fan motor shaft.
Old 05-13-2009, 05:26 PM   #3
tils1975
no power meaning no fan speed, no force from the vents.
Old 05-13-2009, 05:29 PM   #4
tils1975
regarding the other areas i will need to check them tomorrow, any guidence as to the location of each, sorry not a car mechanic. but willing
Old 05-14-2009, 02:53 PM   #5
Big Evil
Big Evil's Avatar
Anything below the windshield where the fresh air intake for the cabin is. If you can find access to an amprobe it's a good way to check how much current the fan motor is pulling (put the inductive loop around the power wire to the motor). Other option is a faulty resistor pack for the fan motor speed selector, but if that goes out you should still have full speed. Can you hear the fan working and just no air coming out? if so that could be a stuck or failed mode select door. Next option may be to go see someone with a scan tool and check for codes but that'll only work if you have auto climate control.
Old 02-21-2011, 04:21 PM   #6
diet
Your Ride: bmw coupe e36 1999
hey while we are on this subject i have S reg 99 e36 bmw climate control and i have the same problem. I put my fan on high speeds and the fan is working but hardly any air coming out through the vents and loop warm not hot. Also when i change direction onto feet or windows doesnt seem to make any difference. is this pollen filter?
BMW E36 M3 SC vs BMW E36 M3 Turbo trev0006 Video and other Multimedia 12 10-16-2007 10:17 AM
