Old 05-06-2009, 01:57 PM   #1
zoe1247
Your Ride: 1994 325is
ABS Light
Recently while driving my ABS and ASC lights come on. After stopping the car and restarting, they will go off. I might drive a week and they do not come on and then they are back on. Could it be a speed sensor. Is there a test to determine which one is causing the problem?
Thank you in advance for your help.
Old 05-06-2009, 05:52 PM   #2
3050rpm
3050rpm's Avatar
It could well be a wheel speed sensor. Just which one it is, and whether the fault is electrical or mechanical, can be determined through electronic diagnostics. An independent shop might run it as a courtesy, I imagine the dealer would almost certainly charge you.
To save you that money, but would involve some labor on your part, I've heard that what you've experienced could be due to no more than a connection which needs to be cleaned. Jack up the respective corner of the car, disconnect the sensor cable, clean it out (compressed air if available), reconnect, and see if that turns the trick. If not, then it's back to step 1.
ABS light Smittythefe E36 0 02-04-2009 03:14 PM
Abs Light On Help gavsav1 E46 0 01-29-2009 04:05 PM
abs light on MBD506 E36 3 03-21-2008 10:08 PM
E30 325is ABS light is on dev6315 E21, E30 8 03-04-2008 07:55 PM
e36 abs idiot light bbimw E36 3 08-07-2007 09:16 PM
