Old 04-30-2009, 07:51 PM   #1
cockey420
Your Ride: 1994 318i
Problem with a 318i (spudders)
Hi eveyone,
I seem to have a problem with my 318i it rides nic3 for a min then is starts to spudder like it want to shut off but it don't. I've replaced the plugs and the wires problem still there so o replaced the distrituter pack (pst) then the mass air flow sensor (pst) now could it be a oxygen sensor or a vaccum leak.
Hope someone can help!!!! thanx
Old 05-01-2009, 12:42 PM   #2
Big Evil
Big Evil's Avatar
Well, without seeing any PID data while the vehicle is running, what your describing sounds like maybe an O2 sensor. If everything is fine until the vehicle enters closed loop operation (first few minutes of running) chances are its not vacuum. Closed loop is when the PCM starts recognizing the input from the O2 and adjusting fuel trim, if the O2 is out of range the PCM can start starving the engine of fuel. Not saying that's it, but it is a likely suspect.
Old 05-01-2009, 10:19 PM   #3
cockey420
Thanx Big Evil i will try this next day. I suspected but was not sure n still not but my baby is worth it. So I'ii let u no how it worked out 4 me..Thanx again
Old 05-07-2009, 11:55 PM   #4
cockey420
Well i changed the o2 sensor and it seem to run better but still a little hessatation when i seat in idle. but now the other problem i have is the all of my gauges stop working and i do mean all of them and across the mile readout i get pppppp (6p)anyone with ideas?
318i se tourer washer problem next35 E46 0 01-21-2009 02:01 PM
325 brake light problem fgmx Lighting 2 02-01-2008 02:52 PM
1998 cut out when hot 318i m43 HELP !!!! andyc E36 4 12-05-2007 04:04 AM
e36 convert problem Butcher E36 3 09-07-2007 06:24 PM
BMW 320i Gas Problem rOMa E36 5 06-27-2007 03:40 AM
