Old 03-13-2009, 10:56 PM   #1
ukcats1996
Your Ride: 325si
obc help
I just got a used 94 325is. I notice the the obc does not work in it. Is it worth me spending the money for a new one or used one? Or will the car run just fine with out it working?
Old 03-20-2009, 05:45 PM   #2
motorwerks
Title: Sitting in Time out
Rate My Car: 158 / 329
Your Ride: '97 328i
The OBC just provides you with warnings about bulbs being out, and low fluids. In my experience it just tells me when I need wiper fluid, and let's me know when another sensor(who's only function is to report to the OBC) has gone bad.
Old 03-20-2009, 07:17 PM   #3
Big Evil
Big Evil's Avatar
Try a trip to the junkyard, may run 5-10 bucks 'cause most those pull it yourself yards don't even know what they're looking at when you go to pay.
Old 03-25-2009, 11:55 PM   #4
C Sean Watts
Name: C Sean Watts
Your Ride: 1997 328is and others
There is a chance
you might just need bulbs.
Old 05-18-2010, 01:28 AM   #5
DSP543GP
Your Ride: 1993 320i
The car will run fine without the obc, obc gives you warning such as failing light, sensors,etc , i would recommend on buying a used one provided it's in good condition especially the 18 buttons . lesser buttons don't have much use for me or new one provided it's not expensive but at the dealers it expensive. Get it or also check the Obc bulbs.
BMW e36 320i
E46 Light Alloy Wheels
Everything standard and original
Ultimate DIY for 18 Button OBC Upgrade from 7 or 11 Button OBC Made Easy w/ Pictures! delmarco BMW OEM Parts Department DIY's & FAQ's 7 12-08-2008 08:39 PM
OBC Security Code sapphiremoon E36 2 10-29-2008 03:20 PM
obc help fourtwenty E36 1 03-26-2008 09:44 AM
Radio and OBC Memory ttr125mar Car Audio and Electronics 1 12-03-2006 08:53 PM
how to unlock the features in the 11 button OBC cabrit E36 15 03-13-2006 08:47 PM
