Old 03-12-2009, 05:57 PM   #1
sim simma
Your Ride: 1993 318is
93 318i wont start
pretty sure this has to do with the alarm. my car died on me and i opened the trunk to get the jumper cables. when i closed the trunk, the alarm went off and i was able to start the car.
is there any way to disable the alarm? i never use it. also, i only have one key and i think my battery in the key is dieing.
any suggestions??? please i'm not sure what to do and i want to get to work and home ok.
Old 03-14-2009, 06:15 PM   #2
Big Evil
Big Evil's Avatar
Not positive on the alarm systems, however I have bypassed the factory systems on other vehicles by jumping a wire and bypassing the starter kill relay in the fuse box. Hope it helps
Old 03-16-2009, 10:46 AM   #3
sim simma
thanks!!!! i'll keep that in mind. i've removed two fuses and i'm hoping that works. up until last night, the car died again while i tried to start it with only one fuse missing. if it is a fuse issue, i don't know which one it is. i've played with removing four fuses, which worked for a day, but i got a new alarm installed and was trying it out with only one fuse missing.
it seems switching the alarm on/off, or opening/closing the trunk, wakes the car up.
we'll see how it works with fuses "8" and "43" missing. it's weird though, because everytime the car acts up it completey resets the battery (or at least the clock and radiostations).
Old 03-16-2009, 04:55 PM   #4
Big Evil
Big Evil's Avatar
Check your battery cables for cleanliness and tightness, battery is back there in the trunk, and opening and closing the trunk may be jarring the cables in and out of contact.
Old 03-19-2009, 09:09 PM   #5
sim simma
wow that was it!!! thanks so much. the battery cables were loose. the ground wire needed some tightening. thanks!!!
Old 03-20-2009, 06:17 PM   #6
Big Evil
Big Evil's Avatar
You welcome :-)
E30 318i Will Not Start mmihacsi E21, E30 17 12-09-2011 07:44 AM
My 93 318i is having electrical oscillation issue, PLEASE HELP!! JoshsE36 E36 6 02-18-2009 03:24 AM
93 no start after battery replacement Not4Hire E36 5 01-15-2008 12:29 PM
325i getting harder and harder to start gdamato E90 9 07-03-2007 09:59 AM
15 Things to do in Wal-Mart komodo Comedy Collection
4 10-05-2005 11:37 AM
