Old 03-02-2009, 04:20 PM   #1
bbmww
Your Ride: 93 318i
idleing problem need help please....
i have a 93 318i, and the problem i have is when u start it from cold the idleing is up and down the hole time until the temp goes up about a quater of the way and it evens out... any ideas wat could be the cause of it and anyway of fixin it...?
Old 03-05-2009, 04:11 AM   #2
falak sher
Your Ride: 1992 bmw e36 316i
does ure car idle fine when engine is hot?
is ure maf sensor working fine?
firstly check for vaccum leaks.
secondly clean the icv valve with carb cleaner and wd 40
thirdly clean the maf sensor element with electrical component cleaner
fourthly check if the two temperature sensors are working fine.
lastly check for leaks in the intake pipe.
try these and ure car will run much better.
Old 03-05-2009, 01:47 PM   #3
bbmww
Your Ride: 93 318i
ya car runs perfect when hot, i have a new icv gone on to it but still same prob.. will check out the maf sensor and temp sensors.... thanks man
A Known Instrument Cluster Problem KickingKing E36 6 11-16-2011 08:50 PM
325 brake light problem fgmx Lighting 2 02-01-2008 01:52 PM
e36 convert problem Butcher E36 3 09-07-2007 05:24 PM
BMW 320i Gas Problem rOMa E36 5 06-27-2007 02:40 AM
528I gear problem, Please help me guys, plz plz djfactor E12, E28, E34, E39, E60 3 10-22-2006 05:56 PM
