Old 02-10-2009, 10:48 PM   #1
falak sher
Your Ride: 1992 bmw e36 316i
hey what is slick 50?
hey guys does anyone know what slick 50 is? my mechanic told me its this white liquid which can be put in old engines for good performance if the piston rings are worn out or if its giving out blue smoke..???
do u think i should use it in my car becuase i have high miles plus my cars burning oil??
hope to hear from you guys soon
Old 02-11-2009, 08:06 AM   #2
motorwerks
Title: Sitting in Time out
Rate My Car: 160 / 337
Your Ride: '97 328i
It's usually recommended not to use oil additives, because in the long term they hurt oil performance.
That aside, I've used slick 50 in non-bmw high mileage vehicles, and it's done wonders. My 170k van wouldn't maintain oil pressure so I tried slick 50, and it's running strong at 190k. I haven't seen the oil pressure drop since using slick 50
Old 02-12-2009, 10:33 PM   #3
falak sher
hey motor werks thanks alot for the help its helped alot.. dude can u just tell me what the procedure is to put slick 50 as in what slick fifty to oil ratio i should follow and should i put it when the car is hot,any details on how to go abt it???..ANd which spark plugs should i put in my e36 316i, currently i have the four pin bosch ones?
hope to hear from you soon bro
Old 02-13-2009, 07:14 AM   #4
motorwerks
Your Ride: '97 328i
The bosch 4 are a waste of money IMO. There are quite a few people on other BMW forums that complain that the bosch 4's caused more problems than anything.
Spark plugs - NGK BKR6E Less than $2 a plug, and they will work as good if not better than every plug on the market.
Replace a quart of oil with a quart of slick 50. You might want to consider running a slightly heavier weight oil as well. This will help keep the oil from leaking out of the seals as fast.
I would change the oil, and run the slick 50 a little bit before changing the plugs. Changing the plugs should fix your power issues, you could also consider "seafoaming". I've never done it on a 4 cyl, but on a six you just run it thought the brake booster line. "youtube" seafoam BMW
Old 02-13-2009, 09:38 PM   #5
falak sher
thanks alot man ure king with this stuff,will tell u how my car runs after all of this thanks once again
Hey all, New here! Looking to buy E36... firezone42 E36 2 02-20-2008 04:14 PM
Hey Jmir14! Cellardoor Introductions and Greetings 4 01-23-2006 02:39 PM
hey hey bimmer spinner defkon99 Bmw Cars For Sale/Wanted 6 11-30-2005 10:58 AM
Hey everyone bmw4life Introductions and Greetings 5 05-02-2005 08:47 PM
Hey new to the forum ///95M3 Introductions and Greetings 10 04-26-2005 08:19 PM
