Old 02-07-2009, 11:26 PM   #1
falak sher
Your Ride: 1992 bmw e36 316i
which engine oil to use in e36?
hey guys i have a 316i e36.
is there any specified engine oil for bmws? because my cars acceleration has died literally so i went to the mechanic for a check up and he said that i need to put synthetic oil because bmws have hydraulic tapits??
i am confused please help.
Old 02-08-2009, 10:50 AM   #2
Tay318
Your Ride: 1994 318IS
Hey. I have an E36 318. when it came time for my first oil change i called the dealership and they told me to use a mineral oil. that would be just fine, but my engine had over 200 000kms on it and i wanted more protection. i talked to a phew mechanic friends and did a little research, i wound up useing Castrol Syntec 5W/30. http://www.castrolsyntec.com/
It is awsome, a little more expensive but it is definatly worth it as the car is worth the money. perfection and cleanliness is key to being a BMW owner, and you'll want to take as good of care on the outside as the engine.
Hope this helps your decision.
Old 02-08-2009, 01:55 PM   #3
AStarps
AStarps's Avatar
Your Ride: 1994 325i
Like tay said, something similar to the Castrol 5W/30 partial synthetic would probably be your best bet. You could run a full synthetic which usually results in slightly better performance, but if you have high miles I wouldn't recommend it because it could start leaking and you don't want that.
The E36. It has unicorns.
Old 02-09-2009, 09:27 AM   #4
Tay318
Agreed. Either way use the good stuff.
Old 02-09-2009, 11:45 AM   #5
falak sher
hey guys thanks alot for the replies and the advice
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 31 11-02-2011 07:28 PM
Engine Differences htp.bmw E21, E30 4 09-19-2007 11:34 AM
Fun With E36 Gauge Cluster Test Functions bitcore BMW OEM Parts Department DIY's & FAQ's 1 05-04-2006 04:08 PM
Amsoil rocks. catalyst E36 26 02-23-2006 12:35 PM
Difference between us/euro spec e36 m3 engine jrhaile M3 7 04-26-2005 12:18 AM
