Old 12-08-2008, 10:00 AM   #1
Mitakid
Your Ride: 98 328i
Bumper Cover repair
My bumper cover has pretty bad road rash to the point where I need to use some sort of filler for some deep gouges.So what I am trying to find out is what is the best material. I want the filler to last and not crack or peel off,the cover is the OEM part,can anybody help? I heard that regular body putty can absorb moisture and crack. Thanks
Mitakid
Old 12-08-2008, 10:46 AM   #2
3050rpm
3050rpm's Avatar
Do you mean the vinyl insert or the fiberglass or vinyl (or whatever it is) portion matched to the color of the body of the car?
Old 12-08-2008, 02:57 PM   #3
Mitakid
Your Ride: 98 328i
The outside cover that matches the color of the car.
Mitakid
Old 12-08-2008, 04:20 PM   #4
3050rpm
3050rpm's Avatar
Although I could be wrong, I doubt that auto body filler would work, adhesion being one possible problem, flexing of the cover being another. I wonder if some type of epoxy is the answer. Check with an auto body shop or car parts place, they might know of something worthwhile short of replacing the entire component.
Old 12-08-2008, 04:58 PM   #5
Mitakid
Your Ride: 98 328i
I found a couple of products that are specifically for flexible parts,
Evercoat Poly-flex,and 3M Automix 5887,although with the 3M you need a gun which is around $80,the filler is around $35 for both.Thanks for the input.
Mitakid
Old 12-08-2008, 05:56 PM   #6
3050rpm
3050rpm's Avatar
Depending upon how much you have to do, and supplying your own labor, the $80 may be worth it, and almost certainly less than what an auto body shop would cost.
Fuel cover won't close MSheraz86 E36 10 11-11-2007 07:52 AM
DIY Changing NON-M to M bumper Rooz BMW OEM Parts Department DIY's & FAQ's 5 08-12-2007 12:44 PM
Torn strut dust cover repair? jerryd E12, E28, E34, E39, E60 0 05-03-2007 09:05 PM
E36 M3 Front Bumper Rooz Bmw Cars For Sale/Wanted 10 11-21-2005 09:01 PM
New bumper maybe? Rooz E36 31 07-29-2005 05:59 PM
